3 if(
4 message(FATAL_ERROR
"CMake >= 2.6.0 required")
15 # Protect against multiple inclusion, which would fail when already imported targets are added once more.
17 set(_targetsNotDefined)
19 foreach(_expectedTarget ParaView::vtkRemotingClientServerStreamPython ParaView::vtkPVVTKExtensionsCorePython ParaView::vtkRemotingCorePython ParaView::vtkRemotingServerManagerPython ParaView::vtkRemotingServerManagerPythonPython ParaView::vtkRemotingLivePython ParaView::vtkRemotingApplicationPython ParaView::vtkRemotingSettingsPython ParaView::vtkPVVTKExtensionsPointsPython ParaView::vtkPVVTKExtensionsIOCorePython ParaView::vtkPVVTKExtensionsIOImagePython ParaView::vtkPVVTKExtensionsFiltersStatisticsPython ParaView::vtkPVVTKExtensionsFiltersPythonPython ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython ParaView::vtkPVVTKExtensionsFiltersGeneralPython ParaView::vtkPVVTKExtensionsFiltersRenderingPython ParaView::vtkPVVTKExtensionsMiscPython ParaView::vtkPVVTKExtensionsExtractionPythonPython ParaView::vtkPVVTKExtensionsExtractionPython ParaView::vtkPVVTKExtensionsConduitPython ParaView::vtkPVVTKExtensionsAMRPython ParaView::vtkPVCatalystPython ParaView::vtkPVAdaptorsPagosaPython ParaView::vtkPVPythonCatalystPython ParaView::vtkPVInSituPython ParaView::pvpythonmodules)
20 list(APPEND _expectedTargets ${_expectedTarget})
21 if(NOT TARGET ${_expectedTarget})
22 list(APPEND _targetsNotDefined ${_expectedTarget})
24 if(TARGET ${_expectedTarget})
25 list(APPEND _targetsDefined ${_expectedTarget})
28 if("${_targetsDefined}
") 29 unset(_targetsDefined) 30 unset(_targetsNotDefined) 31 unset(_expectedTargets) 32 set(CMAKE_IMPORT_FILE_VERSION) 36 if(NOT "${_targetsDefined}
" STREQUAL "") 37 message(FATAL_ERROR "Some (but not all) targets in
this export
") 39 unset(_targetsDefined) 40 unset(_targetsNotDefined) 41 unset(_expectedTargets) 44 # Compute the installation prefix relative to this file. 45 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}
" PATH) 46 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 47 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 48 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 49 if(_IMPORT_PREFIX STREQUAL "/
") 50 set(_IMPORT_PREFIX "") 53 # Create imported target ParaView::vtkRemotingClientServerStreamPython 54 add_library(ParaView::vtkRemotingClientServerStreamPython MODULE IMPORTED) 56 # Create imported target ParaView::vtkPVVTKExtensionsCorePython 57 add_library(ParaView::vtkPVVTKExtensionsCorePython MODULE IMPORTED) 59 # Create imported target ParaView::vtkRemotingCorePython 60 add_library(ParaView::vtkRemotingCorePython MODULE IMPORTED) 62 # Create imported target ParaView::vtkRemotingServerManagerPython 63 add_library(ParaView::vtkRemotingServerManagerPython MODULE IMPORTED) 65 # Create imported target ParaView::vtkRemotingServerManagerPythonPython 66 add_library(ParaView::vtkRemotingServerManagerPythonPython MODULE IMPORTED) 68 # Create imported target ParaView::vtkRemotingLivePython 69 add_library(ParaView::vtkRemotingLivePython MODULE IMPORTED) 71 # Create imported target ParaView::vtkRemotingApplicationPython 72 add_library(ParaView::vtkRemotingApplicationPython MODULE IMPORTED) 74 # Create imported target ParaView::vtkRemotingSettingsPython 75 add_library(ParaView::vtkRemotingSettingsPython MODULE IMPORTED) 77 # Create imported target ParaView::vtkPVVTKExtensionsPointsPython 78 add_library(ParaView::vtkPVVTKExtensionsPointsPython MODULE IMPORTED) 80 # Create imported target ParaView::vtkPVVTKExtensionsIOCorePython 81 add_library(ParaView::vtkPVVTKExtensionsIOCorePython MODULE IMPORTED) 83 # Create imported target ParaView::vtkPVVTKExtensionsIOImagePython 84 add_library(ParaView::vtkPVVTKExtensionsIOImagePython MODULE IMPORTED) 86 # Create imported target ParaView::vtkPVVTKExtensionsFiltersStatisticsPython 87 add_library(ParaView::vtkPVVTKExtensionsFiltersStatisticsPython MODULE IMPORTED) 89 # Create imported target ParaView::vtkPVVTKExtensionsFiltersPythonPython 90 add_library(ParaView::vtkPVVTKExtensionsFiltersPythonPython MODULE IMPORTED) 92 # Create imported target ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython 93 add_library(ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython MODULE IMPORTED) 95 # Create imported target ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython 96 add_library(ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython MODULE IMPORTED) 98 # Create imported target ParaView::vtkPVVTKExtensionsFiltersGeneralPython 99 add_library(ParaView::vtkPVVTKExtensionsFiltersGeneralPython MODULE IMPORTED) 101 # Create imported target ParaView::vtkPVVTKExtensionsFiltersRenderingPython 102 add_library(ParaView::vtkPVVTKExtensionsFiltersRenderingPython MODULE IMPORTED) 104 # Create imported target ParaView::vtkPVVTKExtensionsMiscPython 105 add_library(ParaView::vtkPVVTKExtensionsMiscPython MODULE IMPORTED) 107 # Create imported target ParaView::vtkPVVTKExtensionsExtractionPythonPython 108 add_library(ParaView::vtkPVVTKExtensionsExtractionPythonPython MODULE IMPORTED) 110 # Create imported target ParaView::vtkPVVTKExtensionsExtractionPython 111 add_library(ParaView::vtkPVVTKExtensionsExtractionPython MODULE IMPORTED) 113 # Create imported target ParaView::vtkPVVTKExtensionsConduitPython 114 add_library(ParaView::vtkPVVTKExtensionsConduitPython MODULE IMPORTED) 116 # Create imported target ParaView::vtkPVVTKExtensionsAMRPython 117 add_library(ParaView::vtkPVVTKExtensionsAMRPython MODULE IMPORTED) 119 # Create imported target ParaView::vtkPVCatalystPython 120 add_library(ParaView::vtkPVCatalystPython MODULE IMPORTED) 122 # Create imported target ParaView::vtkPVAdaptorsPagosaPython 123 add_library(ParaView::vtkPVAdaptorsPagosaPython MODULE IMPORTED) 125 # Create imported target ParaView::vtkPVPythonCatalystPython 126 add_library(ParaView::vtkPVPythonCatalystPython MODULE IMPORTED) 128 # Create imported target ParaView::vtkPVInSituPython 129 add_library(ParaView::vtkPVInSituPython MODULE IMPORTED) 131 # Create imported target ParaView::pvpythonmodules 132 add_library(ParaView::pvpythonmodules INTERFACE IMPORTED) 134 set_target_properties(ParaView::pvpythonmodules PROPERTIES 135 INTERFACE_LINK_LIBRARIES "VTK::vtkpythonmodules
" 138 if(CMAKE_VERSION VERSION_LESS 3.0.0) 139 message(FATAL_ERROR "This file relies
on consumers
using CMake 3.0.0 or greater.
") 142 # Load information for each installed configuration. 143 get_filename_component(_DIR "${CMAKE_CURRENT_LIST_FILE}
" PATH) 145 foreach(f ${CONFIG_FILES}) 149 # Cleanup temporary variables. 152 # Loop over all imported files and verify that they actually exist 153 foreach(target ${_IMPORT_CHECK_TARGETS} ) 154 foreach(file ${_IMPORT_CHECK_FILES_FOR_${target}} ) 155 if(NOT EXISTS "${file}
" ) 156 message(FATAL_ERROR "The imported
target \
"${target}\" references the file 158 but this file does not exist. Possible reasons include: 159 * The file was deleted, renamed, or moved to another location. 160 * An install or uninstall procedure did not complete successfully. 161 * The installation package was faulty and contained 162 \"${CMAKE_CURRENT_LIST_FILE}\" 163 but not all the files it references. 167 unset(_IMPORT_CHECK_FILES_FOR_${
target})
169 unset(_IMPORT_CHECK_TARGETS)
171 # Make sure the targets which have been exported in some other 173 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
174 foreach(_target
"VTK::vtkpythonmodules" )
175 if(NOT TARGET
"${_target}" )
176 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets
"${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
180 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
181 if(CMAKE_FIND_PACKAGE_NAME)
182 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
183 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE
"The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
185 message(FATAL_ERROR
188 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
190 # Commands beyond
this point should not need to know the
version.
191 set(CMAKE_IMPORT_FILE_VERSION)
