ParaViewPlugins-targets.cmake
1 # Generated by CMake
5 endif()
6 cmake_policy(PUSH)
7 cmake_policy(VERSION 2.6...3.17)
11
14
16 set(_targetsDefined)
17 set(_targetsNotDefined)
18 set(_expectedTargets)
19 foreach(_expectedTarget ParaView::paraview_plugins)
23  endif()
26  endif()
27 endforeach()
29  unset(_targetsDefined)
30  unset(_targetsNotDefined)
31  unset(_expectedTargets)
33  cmake_policy(POP)
34  return()
35 endif()
39 unset(_targetsDefined)
40 unset(_targetsNotDefined)
41 unset(_expectedTargets)
42
43
44 # Compute the installation prefix relative to this file.
45 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
46 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
47 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
48 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
49 if(_IMPORT_PREFIX STREQUAL "/")
50  set(_IMPORT_PREFIX "")
51 endif()
52
53 # Create imported target ParaView::paraview_plugins
54 add_library(ParaView::paraview_plugins INTERFACE IMPORTED)
55
56 set_target_properties(ParaView::paraview_plugins PROPERTIES
57  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-5.9"
58 )
59
60 if(CMAKE_VERSION VERSION_LESS 3.0.0)
61  message(FATAL_ERROR "This file relies on consumers using CMake 3.0.0 or greater.")
62 endif()
63
64 # Load information for each installed configuration.
65 get_filename_component(_DIR "${CMAKE_CURRENT_LIST_FILE}" PATH)
66 file(GLOB CONFIG_FILES "${_DIR}/ParaViewPlugins-targets-*.cmake")
67 foreach(f ${CONFIG_FILES})
68  include(${f})
69 endforeach()
70
71 # Cleanup temporary variables.
72 set(_IMPORT_PREFIX)
73
74 # Loop over all imported files and verify that they actually exist
75 foreach(target ${_IMPORT_CHECK_TARGETS} )
76  foreach(file ${_IMPORT_CHECK_FILES_FOR_${target}} )
77  if(NOT EXISTS "${file}" )
78  message(FATAL_ERROR "The imported target \"${target}\" references the file
79  \"${file}\"
80 but this file does not exist. Possible reasons include:
81 * The file was deleted, renamed, or moved to another location.
82 * An install or uninstall procedure did not complete successfully.
83 * The installation package was faulty and contained
84  \"${CMAKE_CURRENT_LIST_FILE}\"
85 but not all the files it references.
86 ")
87  endif()
88  endforeach()
89  unset(_IMPORT_CHECK_FILES_FOR_${target})
90 endforeach()
91 unset(_IMPORT_CHECK_TARGETS)
92
93 # This file does not depend on other imported targets which have
94 # been exported from the same project but in a separate export set.
95
96 # Commands beyond this point should not need to know the version.
97 set(CMAKE_IMPORT_FILE_VERSION)
98 cmake_policy(POP)
on
#define VERSION
Definition: jconfigint.h:17
