1 # Install script for directory: /home/paraview/build/CMakeFiles/CheckFortran
15  set(CMAKE_INSTALL_CONFIG_NAME "")
45 if(CMAKE_INSTALL_COMPONENT)
46  set(CMAKE_INSTALL_MANIFEST "install_manifest_${CMAKE_INSTALL_COMPONENT}.txt")
47 else()
48  set(CMAKE_INSTALL_MANIFEST "install_manifest.txt")
49 endif()
50
51 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
52  "${CMAKE_INSTALL_MANIFEST_FILES}")
53 file(WRITE "/home/paraview/build/CMakeFiles/CheckFortran/${CMAKE_INSTALL_MANIFEST}"
54  "${CMAKE_INSTALL_MANIFEST_CONTENT}")
