1 # Install script for directory: /home/paraview/Adaptors/Phasta
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/Adaptors/Phasta/PhastaAdaptor.h"
48  "/home/paraview/build/Adaptors/Phasta/vtkPVAdaptorsPhastaModule.h"
49  )
50 endif()
51
52 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
53  foreach(file
54  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv5.9.so.5.9"
55  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv5.9.so.1"
56  )
57  if(EXISTS "${file}" AND
58  NOT IS_SYMLINK "${file}")
59  file(RPATH_CHECK
60  FILE "${file}"
61  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
62  endif()
63  endforeach()
64  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
65  "/home/paraview/build/lib64/libvtkPVAdaptorsPhasta-pv5.9.so.5.9"
66  "/home/paraview/build/lib64/libvtkPVAdaptorsPhasta-pv5.9.so.1"
67  )
68  foreach(file
69  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv5.9.so.5.9"
70  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv5.9.so.1"
71  )
72  if(EXISTS "${file}" AND
73  NOT IS_SYMLINK "${file}")
74  file(RPATH_CHANGE
75  FILE "${file}"
76  OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:"
77  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
78  if(CMAKE_INSTALL_DO_STRIP)
79  execute_process(COMMAND "/usr/bin/strip" "${file}")
80  endif()
81  endif()
82  endforeach()
83 endif()
84
85 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
86  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv5.9.so" AND
87  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv5.9.so")
88  file(RPATH_CHECK
89  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv5.9.so"
90  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
91  endif()
92  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkPVAdaptorsPhasta-pv5.9.so")
93  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv5.9.so" AND
94  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv5.9.so")
95  file(RPATH_CHANGE
96  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv5.9.so"
97  OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:"
98  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
99  if(CMAKE_INSTALL_DO_STRIP)
100  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv5.9.so")
101  endif()
102  endif()
103 endif()
104
