1 # Install script for directory: /home/paraview/Adaptors/Pagosa 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
"/home/paraview/build/Adaptors/Pagosa/vtkPVAdaptorsPagosaModule.h")
49 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 50 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkPVAdaptorsPagosa-hierarchy.txt
" FILES "/home/paraview/build/lib64/
vtk/hierarchy/ParaView/vtkPVAdaptorsPagosa-hierarchy.txt
") 53 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 55 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.9.so.5.9
" 56 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.9.so.1
" 58 if(EXISTS "${file}
" AND 59 NOT IS_SYMLINK "${file}
") 62 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 65 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 66 "/home/paraview/build/lib64/libvtkPVAdaptorsPagosa-pv5.9.so.5.9
" 67 "/home/paraview/build/lib64/libvtkPVAdaptorsPagosa-pv5.9.so.1
" 70 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.9.so.5.9
" 71 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.9.so.1
" 73 if(EXISTS "${file}
" AND 74 NOT IS_SYMLINK "${file}
") 77 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 78 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 79 if(CMAKE_INSTALL_DO_STRIP) 80 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 86 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 87 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.9.so
" AND 88 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.9.so
") 90 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.9.so
" 91 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 93 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkPVAdaptorsPagosa-pv5.9.so
") 94 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.9.so
" AND 95 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.9.so
") 97 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.9.so
" 98 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 99 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 100 if(CMAKE_INSTALL_DO_STRIP) 101 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.9.so
