1 # Install script for directory: /home/paraview/Adaptors/Cam 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/Adaptors/Cam/fv_create_data.h" 48 "/home/paraview/Adaptors/Cam/se_create_data.h" 49 "/home/paraview/Adaptors/Cam/Grid.h" 50 "/home/paraview/build/Adaptors/Cam/vtkPVAdaptorsCamModule.h" 51 "/home/paraview/Adaptors/Cam/Grid.txx" 55 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 57 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv5.9.so.5.9
" 58 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv5.9.so.1
" 60 if(EXISTS "${file}
" AND 61 NOT IS_SYMLINK "${file}
") 64 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 67 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 68 "/home/paraview/build/lib64/libvtkPVAdaptorsCam-pv5.9.so.5.9
" 69 "/home/paraview/build/lib64/libvtkPVAdaptorsCam-pv5.9.so.1
" 72 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv5.9.so.5.9
" 73 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv5.9.so.1
" 75 if(EXISTS "${file}
" AND 76 NOT IS_SYMLINK "${file}
") 79 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 80 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 81 if(CMAKE_INSTALL_DO_STRIP) 82 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 88 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 89 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv5.9.so
" AND 90 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv5.9.so
") 92 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv5.9.so
" 93 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 95 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkPVAdaptorsCam-pv5.9.so
") 96 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv5.9.so
" AND 97 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv5.9.so
") 99 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv5.9.so
" 100 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 101 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 102 if(CMAKE_INSTALL_DO_STRIP) 103 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv5.9.so
