1 # Install script for directory: /home/paraview/Adaptors/Cam/Python
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages" TYPE FILE FILES "/home/paraview/Adaptors/Cam/Python/fv_coprocess.py")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages" TYPE FILE FILES "/home/paraview/Adaptors/Cam/Python/se_coprocess.py")
51 endif()
52
