CMakeFortranCompiler.cmake
1 set(CMAKE_Fortran_COMPILER "/usr/bin/f95")
2 set(CMAKE_Fortran_COMPILER_ARG1 "")
3 set(CMAKE_Fortran_COMPILER_ID "GNU")
4 set(CMAKE_Fortran_COMPILER_VERSION "10.2.1")
5 set(CMAKE_Fortran_COMPILER_WRAPPER "")
6 set(CMAKE_Fortran_PLATFORM_ID "")
7 set(CMAKE_Fortran_SIMULATE_ID "")
8 set(CMAKE_Fortran_SIMULATE_VERSION "")
9
10
11
12
13 set(CMAKE_AR "/usr/bin/ar")
14 set(CMAKE_Fortran_COMPILER_AR "/usr/bin/gcc-ar")
15 set(CMAKE_RANLIB "/usr/bin/ranlib")
16 set(CMAKE_Fortran_COMPILER_RANLIB "/usr/bin/gcc-ranlib")
17 set(CMAKE_COMPILER_IS_GNUG77 1)
18 set(CMAKE_Fortran_COMPILER_LOADED 1)
19 set(CMAKE_Fortran_COMPILER_WORKS TRUE)
20 set(CMAKE_Fortran_ABI_COMPILED TRUE)
21 set(CMAKE_COMPILER_IS_MINGW )
22 set(CMAKE_COMPILER_IS_CYGWIN )
23 if(CMAKE_COMPILER_IS_CYGWIN)
24  set(CYGWIN 1)
25  set(UNIX 1)
26 endif()
27
28 set(CMAKE_Fortran_COMPILER_ENV_VAR "FC")
30 set(CMAKE_Fortran_COMPILER_SUPPORTS_F90 1)
31
32 if(CMAKE_COMPILER_IS_MINGW)
33  set(MINGW 1)
34 endif()
35 set(CMAKE_Fortran_COMPILER_ID_RUN 1)
36 set(CMAKE_Fortran_SOURCE_FILE_EXTENSIONS f;F;fpp;FPP;f77;F77;f90;F90;for;For;FOR;f95;F95)
37 set(CMAKE_Fortran_IGNORE_EXTENSIONS h;H;o;O;obj;OBJ;def;DEF;rc;RC)
38 set(CMAKE_Fortran_LINKER_PREFERENCE 20)
39 if(UNIX)
40  set(CMAKE_Fortran_OUTPUT_EXTENSION .o)
41 else()
42  set(CMAKE_Fortran_OUTPUT_EXTENSION .obj)
45 # Save compiler ABI information.
46 set(CMAKE_Fortran_SIZEOF_DATA_PTR "8")
47 set(CMAKE_Fortran_COMPILER_ABI "")
48 set(CMAKE_Fortran_LIBRARY_ARCHITECTURE "")
49
50 if(CMAKE_Fortran_SIZEOF_DATA_PTR AND NOT CMAKE_SIZEOF_VOID_P)
51  set(CMAKE_SIZEOF_VOID_P "${CMAKE_Fortran_SIZEOF_DATA_PTR}")
52 endif()
53
54 if(CMAKE_Fortran_COMPILER_ABI)
55  set(CMAKE_INTERNAL_PLATFORM_ABI "${CMAKE_Fortran_COMPILER_ABI}")
56 endif()
57
58 if(CMAKE_Fortran_LIBRARY_ARCHITECTURE)
59  set(CMAKE_LIBRARY_ARCHITECTURE "")
60 endif()
61
62
63
64
65
66 set(CMAKE_Fortran_IMPLICIT_INCLUDE_DIRECTORIES "/usr/lib/gcc/x86_64-redhat-linux/10/finclude;/usr/lib/gcc/x86_64-redhat-linux/10/include;/usr/local/include;/usr/include")
67 set(CMAKE_Fortran_IMPLICIT_LINK_LIBRARIES "c;c;gfortran;m;gcc_s;gcc;quadmath;m;gcc_s;gcc;c;gcc_s;gcc")
68 set(CMAKE_Fortran_IMPLICIT_LINK_DIRECTORIES "/usr/lib/gcc/x86_64-redhat-linux/10;/usr/lib64;/lib64;/usr/lib")
69 set(CMAKE_Fortran_IMPLICIT_LINK_FRAMEWORK_DIRECTORIES "")
