TestDriver
vtkSMTestDriverConfig.h
1
// SPDX-FileCopyrightText: Copyright (c) Kitware Inc.
// SPDX-License-Identifier: BSD-3-Clause
3
/* #undef PV_TEST_INIT_COMMAND */
4
/* #undef PV_TEST_CLEAN_COMMAND */
5
6
// host name for the client used when running reverse connect test.
7
#define PV_TEST_CLIENT "localhost"
9
// ssh command to connect to remote machine, usually ssh -l kitware dash8
10
/* #undef PV_SSH_FLAGS */
11
12
// shell script to execute server, should contain proper port...
13
// This line won't be split into smaller arguments
14
/* #undef PV_SETUP_SCRIPT */
15
16
// if defined we use random port numbers for testing (needed for parallel
17
// tests).
18
#define PV_TEST_USE_RANDOM_PORTS
