1 # Tests that require python 3 list(APPEND TESTS_WITHOUT_BASELINES
7 MultipleNumberOfComponents.xml
8 ProgrammableSourcePythonEditorLink.xml
10 PythonResetSessionMacro.xml
11 SpreadSheetNullArrayName.xml # needs programmable filter
12 # TestPopOutWidget.xml
14 TraceIntegrateVariables.xml
17 # This test rely on copy being Ctrl-C 19 list(APPEND TESTS_WITHOUT_BASELINES
21 TestHTGHoverOnCell.xml
25 list(APPEND TESTS_WITH_BASELINES
26 ColorByComponentNames.xml
# needs programmable filter 27 LiveProgrammableSource.xml
30 PythonShellRunScript.xml
32 SaveLoadStatePython.xml
33 SaveLoadStateSelectionPython.xml
35 TraceExportAndSaveData.xml
37 # TraceStatisticsFilter.xml (see paraview/paraview#20661. Also was disabled in CS/CRS mode) 38 TraceSupplementalProxiesFully.xml
40 TraceWithoutRenderingComponents.xml
42 # Surface selection unstable on CRS mode
43 set(SaveLoadStateSelectionPython_DISABLE_CRS TRUE)
45 list(APPEND TESTS_WITH_INLINE_COMPARES
46 RestoreArrayDefaultTransferFunction.xml
47 RestoreDefaultTransferFunction.xml
49 SelectionLinkScripting.xml
54 set(SelectCellsTrace_DISABLE_CRS TRUE)
55 set(SelectPointsTrace_DISABLE_CRS TRUE)
57 # Check that matplotlib is available 58 include(ParaViewFindPythonModules)
61 list(APPEND TESTS_WITH_BASELINES TestPythonView.xml)
62 list(APPEND TESTS_WITH_INLINE_COMPARES TextSourceInteriorLines.xml)
63 list(APPEND TESTS_WITH_INLINE_COMPARES TextSourcesInChartViews.xml)
64 list(APPEND TESTS_WITH_INLINE_COMPARES MathTextColumn.xml)
69 list(APPEND TESTS_WITH_BASELINES
70 AnnotateNotSanitizedArray.xml
71 ContextViewSelectionTrace.xml
73 FindDataNameSanitization.xml
74 FindDataNonDistributedData.xml
75 FindDataPartialArrays.xml
76 FindDataSelectLocationMultiblock.xml
# find data needs python/numpy 77 FindDataSelectLocation.xml # find
81 FreezeQueryMultiblock.xml
82 IndexedLookupInitialization.xml # needs Python Calculator/numpy
83 PlotOverLine_surface.xml # needs find
data 84 ProgrammableAnnotation.xml
85 SpreadSheetSelectionTrace.xml
86 StructuredGridCellBlanking.xml
87 VolumeNoMapScalars.xml # needs programmable filter + numpy
90 list(APPEND TESTS_WITHOUT_BASELINES
93 FieldDataDomainDefault.xml
94 HyperTreeGridVisibleLeavesSize.xml
95 PlotOverLine_htg.xml # needs find data
96 ProgrammableFilterFieldData.xml
98 PythonCalculatorArrayAssociation.xml
99 PythonCalculatorAutocomplete.xml
100 PythonCalculatorCrossComposite.xml
101 PythonCalculatorFieldData.xml
102 PythonCalculatorInput.xml
103 PythonCalculatorMultiline.xml
106 set(SpreadSheetSelectionTrace_DISABLE_CS TRUE)
107 set(SpreadSheetSelectionTrace_DISABLE_CRS TRUE)
109 list(APPEND TESTS_WITH_INLINE_COMPARES
112 TestTableFFT.xml # needs programmable filter + numpy
115 # PythonAlgorithm plugin tests. 117 "PythonAlgorithmPlugin.xml.in" 118 "${CMAKE_CURRENT_BINARY_DIR}/PythonAlgorithmPlugin.xml" @ONLY)
120 "PythonAlgorithmReadersAndWriters.xml.in" 121 "${CMAKE_CURRENT_BINARY_DIR}/PythonAlgorithmReadersAndWriters.xml" @ONLY)
123 set(pyalgo_plugin_tests
124 PythonAlgorithmPlugin
125 PythonAlgorithmReadersAndWriters)
126 foreach(tname IN LISTS pyalgo_plugin_tests)
127 list(APPEND TESTS_WITH_BASELINES
128 ${CMAKE_CURRENT_BINARY_DIR}/${tname}.xml)
130 # we need to extend testing infrastructure to better support
131 # loading plugins in client-server. At that point, we can test these as well.
132 set(${tname}_DISABLE_CS TRUE)
133 set(${tname}_DISABLE_CRS TRUE)
137 #---------------------------------------------------------------------- 138 # Tests that produce some output (other than rendered images) from ParaView 139 # that should be checked for correctness. These work by executing an XML 140 # test in the UI that produces some output, then pvpython runs a Python script 141 # that checks the file for correctness. Example use: checking a CSV 142 # file for expected content. 144 # Tests listed here are required to define the following files: 145 # - <test>.xml - XML test script to play in the uI 146 # - <test>Verify.py - Python code to verify output saved out in the XML 148 #---------------------------------------------------------------------- 149 set(paraview_python_verify_tests
150 ExportMultiblockFieldDataSpreadsheet
151 ExportSceneSpreadSheetView
154 if (PARAVIEW_ENABLE_WEB)
155 list(APPEND paraview_python_verify_tests
161 foreach(test_name ${paraview_python_verify_tests})
162 set(tname
"ParaView::Applications::${test_name}")
163 add_test(
NAME ${tname}
164 COMMAND ${CMAKE_COMMAND}
165 -DPARAVIEW_EXECUTABLE:FILEPATH=$<TARGET_FILE:ParaView::paraview>
166 -DPVPYTHON_EXECUTABLE:FILEPATH=$<TARGET_FILE:ParaView::pvpython>
167 -DDATA_DIR:PATH=${paraview_test_data_directory_output}
168 -DTEST_NAME:STRING=${test_name}
169 -DTEST_SCRIPT:FILEPATH=${CMAKE_CURRENT_SOURCE_DIR}/${test_name}.xml
170 -DTEST_VERIFIER:FILEPATH=${CMAKE_CURRENT_SOURCE_DIR}/${test_name}Verify.py
171 -DTEMPORARY_DIR:PATH=${CMAKE_BINARY_DIR}/Testing/Temporary
172 -P ${CMAKE_CURRENT_SOURCE_DIR}/PythonScriptTestDriver.cmake
174 set_tests_properties(${tname} PROPERTIES
LABELS "paraview")
function find_python_module(module_name, result)
#define PARAVIEW_USE_PYTHON
