2 # paraview-config.cmake 4 This file is used by CMake when finding ParaView.
6 The following variables are provided by
this module:
8 * `ParaView_VERSION`: The full
version of ParaView found.
9 * `ParaView_VERSION_SIMPLE`: The simple
version of ParaView found (eg: 5.9.1).
10 * `ParaView_VERSION_MAJOR`: The major
11 * `ParaView_VERSION_MINOR`: The minor
12 * `ParaView_VERSION_PATCH`: The patch
13 * `ParaView_PREFIX_PATH`: Install prefix
for ParaView.
14 * `PARAVIEW_USE_QT`: If ParaView
's Qt GUI is available. 15 * `PARAVIEW_QT_MAJOR_VERSION`: Major version of Qt used by ParaView if PARAVIEW_USE_QT is TRUE 16 * `PARAVIEW_USE_MPI`: If ParaView is built with MPI support. 17 * `PARAVIEW_USE_PYTHON`: If ParaView is built with Python support. 18 * `PARAVIEW_USE_SERIALIZATION`: If ParaView is built with Serialization support. 19 * `PARAVIEW_USE_QTWEBENGINE`: If ParaView uses Qt's WebEngine
for its help.
20 * `PARAVIEW_PYTHONPATH`: Where ParaView
's Python modules live under the 21 install prefix. Unset if Python is not available. 22 * `PARAVIEW_PLUGIN_SUBDIR`: The subdirectory under the library directory for 24 * `ParaView_CLIENT_XML_FILES`: XML files for client applications to use to 25 reproduce ParaView's menu items. Only provided
if `PARAVIEW_USE_QT`
27 * `ParaView_LIBRARIES`: The list of modules specified by `COMPONENTS` and
28 `OPTIONAL_COMPONENTS`. This may be used in `MODULES` arguments in the API
29 (e.g., `vtk_module_autoinit`). All modules are also targets and may be
30 linked to
using `target_link_libraries`.
31 * `ParaView_CATALYST_DIR`: The directory to the ParaView Catalyst
32 implementation (
if present).
35 if (CMAKE_VERSION VERSION_LESS
"3.12")
36 set(
"${CMAKE_FIND_PACKAGE_NAME}_FOUND" 0)
37 set(
"${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE" 38 "ParaView requires CMake 3.12 in order to reliably be used.")
45 set(${CMAKE_FIND_PACKAGE_NAME}_CMAKE_MODULE_PATH_save
"${CMAKE_MODULE_PATH}")
46 list(INSERT CMAKE_MODULE_PATH 0
47 "${CMAKE_CURRENT_LIST_DIR}")
49 set(
"${CMAKE_FIND_PACKAGE_NAME}_CMAKE_PREFIX_PATH_save" "${CMAKE_PREFIX_PATH}")
50 include(
"${CMAKE_CURRENT_LIST_DIR}/paraview-prefix.cmake")
51 set(
"${CMAKE_FIND_PACKAGE_NAME}_PREFIX_PATH" 52 "${_vtk_module_import_prefix}")
53 unset(_vtk_module_import_prefix)
54 list(INSERT CMAKE_PREFIX_PATH 0
55 "${${CMAKE_FIND_PACKAGE_NAME}_PREFIX_PATH}")
57 set(
"${CMAKE_FIND_PACKAGE_NAME}_VERSION" "5.13.2")
58 set(
"${CMAKE_FIND_PACKAGE_NAME}_VERSION_SIMPLE" "5.13")
59 set(
"${CMAKE_FIND_PACKAGE_NAME}_VERSION_MAJOR" "5")
60 set(
"${CMAKE_FIND_PACKAGE_NAME}_VERSION_MINOR" "13")
61 set(
"${CMAKE_FIND_PACKAGE_NAME}_VERSION_PATCH" "2")
63 unset(
"${CMAKE_FIND_PACKAGE_NAME}_FOUND")
65 set(_paraview_use_external_vtk
"OFF")
66 set(_paraview_find_package_args)
67 if (${CMAKE_FIND_PACKAGE_NAME}_FIND_QUIETLY)
68 list(APPEND _paraview_find_package_args
71 if (NOT _paraview_use_external_vtk)
72 list(APPEND _paraview_find_package_args
73 PATHS "${CMAKE_CURRENT_LIST_DIR}/
vtk" 75 # Find VTK with just `CommonCore` to get the available targets first. Only 76 # required for a vendored VTK since external targets are not checked by CMake 78 find_package(VTK REQUIRED 79 ${_paraview_find_package_args} 80 COMPONENTS CommonCore) 82 unset(_paraview_use_external_vtk) 84 set(PARAVIEW_USE_QT "ON
") 85 set(PARAVIEW_QT_MAJOR_VERSION "5
") 86 set(PARAVIEW_USE_MPI "ON
") 87 set(PARAVIEW_USE_PYTHON "ON
") 88 set(PARAVIEW_USE_SERIALIZATION "OFF
") 89 set(PARAVIEW_USE_QTWEBENGINE "OFF
") 90 set(PARAVIEW_PLUGIN_SUBDIR "paraview-5.13/plugins
") 92 if (PARAVIEW_USE_PYTHON) 93 set(PARAVIEW_PYTHONPATH "lib64/python3.10/site-packages
") 95 include("${CMAKE_CURRENT_LIST_DIR}/ParaViewPythonIncubator-targets.cmake
") 96 # Unset this for now; these targets will be defined later. 97 unset("${CMAKE_FIND_PACKAGE_NAME}_FOUND
") 98 unset("${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE
") 101 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}-targets.cmake
") 102 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}-
vtk-module-properties.cmake
") 104 include("${CMAKE_CURRENT_LIST_DIR}/paraview-find-package-helpers.cmake
" OPTIONAL) 105 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}-
vtk-module-find-packages.cmake
") 107 if ("INCUBATOR
" IN_LIST "${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS
") 108 list(REMOVE_ITEM "${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS
" 110 # This component is always found. 111 set("${CMAKE_FIND_PACKAGE_NAME}_INCUBATOR_FOUND
" 1) 113 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}Incubator-targets.cmake
") 114 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}Incubator-
") 115 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}Incubator-
") 117 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}Incubator-targets.cmake
") 119 set("${CMAKE_FIND_PACKAGE_NAME}_INCUBATOR_FOUND
" 0) 120 set("${CMAKE_FIND_PACKAGE_NAME}_INCUBATOR_NOT_FOUND_MESSAGE
" "the `INCUBATOR`
component was not requested
") 123 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}Plugins-paraview_plugins-targets-depends.cmake
") 124 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}Plugins-targets.cmake
") 125 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}Plugins-paraview-plugin-properties.cmake
") 127 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}Clients-targets.cmake
") 128 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}Clients-
") 130 include("${CMAKE_CURRENT_LIST_DIR}/ParaViewTools-targets.cmake
" OPTIONAL) 132 # Gather the list of required VTK components. 133 set(_paraview_vtk_components_to_request_required) 134 set(_paraview_vtk_components_to_request_optional) 135 if (${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS) 136 set(_paraview_search_components 137 "${${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS}
") 139 set(_paraview_search_components 140 "WrapClientServer;smTestDriver;PythonInterpreterPath;PythonInitializer;ProcessXML;CinemaSci;CinemaPython;icet;RemotingViewsPython;RemotingServerManagerPython;PVWebPython;VTKExtensionsPoints;VTKExtensionsIOSPCTH;VTKExtensionsIOParallelCGNSWriter;VTKExtensionsIOImage;VTKExtensionsIOExodus;VTKExtensionsIOEnSight;VTKExtensionsIOCGNSWriter;VTKExtensionsIOAMR;VTKExtensionsFiltersStatistics;VTKExtensionsFiltersPython;VTKExtensionsFiltersParallelDIY2;VTKExtensionsFiltersParallel;VTKExtensionsFiltersMaterialInterface;VTKExtensionsFiltersGeneralMPI;VTKExtensionsFiltersFlowPaths;VTKExtensionsExtractionPython;pqPython;pqApplicationComponents;RemotingImport;VTKExtensionsIOImport;RemotingExport;pqComponents;RemotingLive;pqCore;RemotingMisc;VTKExtensionsIOGeneral;VTKExtensionsFiltersGeneral;VTKExtensionsAMR;RemotingApplication;RemotingSettings;RemotingAnimation;VTKExtensionsIOCore;RemotingViews;VTKExtensionsInteractionStyle;VTKExtensionsFiltersRendering;VTKExtensionsMisc;VTKExtensionsExtraction;pqWidgets;RemotingServerManager;protobuf;RemotingCore;VTKExtensionsCore;RemotingClientServerStream;Versioning;qttesting;AdaptorsPython;AdaptorsPhasta;AdaptorsParticle;AdaptorsPagosa;AdaptorsNPIC;AdaptorsCamPython;AdaptorsCam;AdaptorsCTH;ClientsWeb;PythonCatalyst;InSitu;Catalyst
") 142 foreach (_paraview_component IN LISTS "${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS
") 143 # Ignore non-existent components here. 144 if (NOT TARGET "ParaView::${_paraview_component}
") 148 # Get all module dependencies. 149 get_property(_paraview_component_depends 150 TARGET "ParaView::${_paraview_component}
" 151 PROPERTY "INTERFACE_vtk_module_depends
") 152 get_property(_paraview_component_private_depends 153 TARGET "ParaView::${_paraview_component}
" 154 PROPERTY "INTERFACE_vtk_module_private_depends
") 155 get_property(_paraview_component_optional_depends 156 TARGET "ParaView::${_paraview_component}
" 157 PROPERTY "INTERFACE_vtk_module_optional_depends
") 159 # Keep only VTK dependencies. 160 set(_paraview_component_vtk_depends 161 ${_paraview_component_depends} 162 ${_paraview_component_private_depends}) 163 set(_paraview_component_vtk_optional_depends 164 ${_paraview_component_optional_depends}) 165 list(FILTER _paraview_component_vtk_depends INCLUDE REGEX "^VTK::
") 166 list(FILTER _paraview_component_vtk_optional_depends INCLUDE REGEX "^VTK::
") 167 string(REPLACE "VTK::
" "" _paraview_component_vtk_depends "${_paraview_component_vtk_depends}
") 168 string(REPLACE "VTK::
" "" _paraview_component_vtk_optional_depends "${_paraview_component_vtk_optional_depends}
") 169 if (${CMAKE_FIND_PACKAGE_NAME}_FIND_REQUIRED_${_paraview_component}) 170 list(APPEND _paraview_vtk_components_to_request_required 171 ${_paraview_component_vtk_depends}) 173 list(APPEND _paraview_vtk_components_to_request_optional 174 ${_paraview_component_vtk_depends}) 176 list(APPEND _paraview_vtk_components_to_request_optional 177 ${_paraview_component_vtk_optional_depends}) 179 unset(_paraview_component) 180 unset(_paraview_component_depends) 181 unset(_paraview_component_private_depends) 182 unset(_paraview_component_optional_depends) 183 unset(_paraview_component_vtk_optional_depends) 184 unset(_paraview_component_vtk_depends) 186 # Remove duplicate component requests. 187 if (_paraview_vtk_components_to_request_required) 188 list(REMOVE_DUPLICATES _paraview_vtk_components_to_request_required) 190 if (_paraview_vtk_components_to_request_optional) 191 list(REMOVE_DUPLICATES _paraview_vtk_components_to_request_optional) 193 # Modules which are required should be removed from the optional component 195 if (_paraview_vtk_components_to_request_required) 196 list(REMOVE_ITEM _paraview_vtk_components_to_request_optional 197 ${_paraview_vtk_components_to_request_required}) 200 # Now find VTK with all of the components we require. 201 find_package(VTK REQUIRED 202 ${_paraview_find_package_args} 203 COMPONENTS ${_paraview_vtk_components_to_request_required} 204 OPTIONAL_COMPONENTS ${_paraview_vtk_components_to_request_optional}) 206 set("${CMAKE_FIND_PACKAGE_NAME}_FOUND
" 0) 208 unset(_paraview_find_package_args) 209 unset(_paraview_vtk_components_to_request_required) 210 unset(_paraview_vtk_components_to_request_optional) 212 include("${CMAKE_CURRENT_LIST_DIR}/ParaViewClient.cmake
") 213 include("${CMAKE_CURRENT_LIST_DIR}/ParaViewPlugin.cmake
") 214 include("${CMAKE_CURRENT_LIST_DIR}/ParaViewServerManager.cmake
") 215 include("${CMAKE_CURRENT_LIST_DIR}/ParaViewTesting.cmake
") 216 include("${CMAKE_CURRENT_LIST_DIR}/vtkModuleWrapClientServer.cmake
") 218 include("${CMAKE_CURRENT_LIST_DIR}/ParaViewTranslations.cmake
") 220 if (0) # paraview_has_catalyst 221 set("${CMAKE_FIND_PACKAGE_NAME}_CATALYST_DIR
" 222 "${${CMAKE_FIND_PACKAGE_NAME}_PREFIX_PATH}/
") 225 if (ON) # PARAVIEW_USE_PYTHON 226 include("${CMAKE_CURRENT_LIST_DIR}/paraview.modules-
vtk-python-module-properties.cmake
") 228 if(${CMAKE_FIND_PACKAGE_NAME}_INCUBATOR_FOUND) 229 include("${CMAKE_CURRENT_LIST_DIR}/paraview.incubator-
") 233 if (ON) # PARAVIEW_USE_QT 234 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}Client-targets.cmake
") 235 include("${CMAKE_CURRENT_LIST_DIR}/ParaView-client-xml.cmake
") 238 set(_paraview_components_to_check) 239 foreach (_paraview_component IN LISTS "${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS
") 240 if (DEFINED "${CMAKE_FIND_PACKAGE_NAME}_${_paraview_component}_FOUND
") 241 # It was already not-found (likely due to `find-package` failures). 242 elseif (TARGET "${CMAKE_FIND_PACKAGE_NAME}::${_paraview_component}
") 243 list(APPEND _paraview_components_to_check 244 "${_paraview_component}
") 246 set("${CMAKE_FIND_PACKAGE_NAME}_${_paraview_component}_FOUND
" 0) 247 list(APPEND "${CMAKE_FIND_PACKAGE_NAME}_${_paraview_component}_NOT_FOUND_MESSAGE
" 248 "The ${_paraview_component}
component is not available.
") 251 unset(_paraview_component) 253 set(_paraview_vtk_components) 255 while (_paraview_components_to_check) 256 list(GET _paraview_components_to_check 0 _paraview_component) 257 list(REMOVE_AT _paraview_components_to_check 0) 258 if (DEFINED "${CMAKE_FIND_PACKAGE_NAME}_${_paraview_component}_FOUND
") 259 # We've already made a determiniation. 263 get_property(_paraview_dependencies 264 TARGET "${CMAKE_FIND_PACKAGE_NAME}::${_paraview_component}
" 265 PROPERTY "INTERFACE_paraview_module_depends
") 266 string(REPLACE "${CMAKE_FIND_PACKAGE_NAME}::
" "" _paraview_dependencies "${_paraview_dependencies}
") 267 set(_paraview_all_dependencies_checked TRUE) 268 foreach (_paraview_dependency IN LISTS _paraview_dependencies) 269 # Handle VTK module dependencies. 270 string(FIND "${_paraview_component}
" "VTK::
" _paraview_vtk_idx) 271 if (NOT _paraview_vtk_idx EQUAL -1) 272 unset(_paraview_vtk_idx) 273 if (NOT TARGET "${_paraview_dependency}
") 274 set("${CMAKE_FIND_PACKAGE_NAME}_${_paraview_component}_FOUND
" 0) 275 list(APPEND "${CMAKE_FIND_PACKAGE_NAME}_${_paraview_component}_NOT_FOUND_MESSAGE
" 276 "Failed to find the ${_paraview_dependency} module.
") 280 unset(_paraview_vtk_idx) 282 if (DEFINED "${CMAKE_FIND_PACKAGE_NAME}_${_paraview_dependency}_FOUND
") 283 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_${_paraview_dependency}_FOUND) 284 set("${CMAKE_FIND_PACKAGE_NAME}_${_paraview_component}_FOUND
" 0) 285 list(APPEND "${CMAKE_FIND_PACKAGE_NAME}_${_paraview_component}_NOT_FOUND_MESSAGE
" 286 "Failed to find the ${_paraview_dependency}
component.
") 289 # Check its dependencies. 290 list(APPEND _paraview_components_to_check 291 "${_paraview_dependency}
") 292 set(_paraview_all_found FALSE) 295 if (NOT DEFINED "${CMAKE_FIND_PACKAGE_NAME}_${_paraview_component}_FOUND
") 296 if (_paraview_all_dependencies_checked) 297 set("${CMAKE_FIND_PACKAGE_NAME}_${_paraview_component}_FOUND
" 1) 299 list(APPEND _paraview_components_to_check 300 "${_paraview_component}
") 303 unset(_paraview_all_dependencies_checked) 304 unset(_paraview_dependency) 305 unset(_paraview_dependencies) 307 unset(_paraview_component) 308 unset(_paraview_components_to_check) 310 set(_paraview_missing_components) 311 foreach (_paraview_component IN LISTS "${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS
") 312 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_${_paraview_component}_FOUND AND ${CMAKE_FIND_PACKAGE_NAME}_FIND_REQUIRED_${_paraview_component}) 313 list(APPEND _paraview_missing_components 314 "${_paraview_component}
") 318 if (_paraview_missing_components) 319 list(REMOVE_DUPLICATES _paraview_missing_components) 320 list(SORT _paraview_missing_components) 321 string(REPLACE ";
" _paraview_missing_components "${_paraview_missing_components}
") 322 set("${CMAKE_FIND_PACKAGE_NAME}_FOUND
" 0) 323 set("${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE
" 324 "Could not find the ${CMAKE_FIND_PACKAGE_NAME}
package with the following required components: ${_paraview_missing_components}.")
326 unset(_paraview_missing_components)
328 set("${CMAKE_FIND_PACKAGE_NAME}_LIBRARIES")
329 if (NOT DEFINED "${CMAKE_FIND_PACKAGE_NAME}_FOUND")
330 # If nothing went wrong, we've successfully found the package.
331 set("${CMAKE_FIND_PACKAGE_NAME}_FOUND" 1)
332 # Build the `_LIBRARIES` variable.
333 foreach (_paraview_component IN LISTS "${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS")
334 list(APPEND "${CMAKE_FIND_PACKAGE_NAME}_LIBRARIES"
335 "${CMAKE_FIND_PACKAGE_NAME}::${_paraview_component}")
337 unset(_paraview_component)
340 set(CMAKE_PREFIX_PATH "${${CMAKE_FIND_PACKAGE_NAME}_CMAKE_PREFIX_PATH_save}")
341 unset("${CMAKE_FIND_PACKAGE_NAME}_CMAKE_PREFIX_PATH_save")
343 set(CMAKE_MODULE_PATH "${${CMAKE_FIND_PACKAGE_NAME}_CMAKE_MODULE_PATH_save}")
344 unset(${CMAKE_FIND_PACKAGE_NAME}_CMAKE_MODULE_PATH_save)
346 # Compatibility with old code.
347 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_FIND_VERSION)
348 set(PARAVIEW_USE_FILE "${CMAKE_CURRENT_LIST_DIR}/paraview-use-file-deprecated.cmake")
349 elseif (${CMAKE_FIND_PACKAGE_NAME}_FIND_VERSION VERSION_LESS 5.7)
350 set(PARAVIEW_USE_FILE "${CMAKE_CURRENT_LIST_DIR}/paraview-use-file-compat.cmake")
352 set(PARAVIEW_USE_FILE "${CMAKE_CURRENT_LIST_DIR}/paraview-use-file-error.cmake")
355 # 5.8 renamed these variables, so provide them if 5.8 is not the minimum
357 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_FIND_VERSION OR
358 ${CMAKE_FIND_PACKAGE_NAME}_FIND_VERSION VERSION_LESS "5.8")
359 set(PARAVIEW_BUILD_QT_GUI "${PARAVIEW_USE_QT}")
360 set(PARAVIEW_ENABLE_PYTHON "${PARAVIEW_USE_PYTHON}")
