1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkxdmf2/libsrc" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/Xdmf.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfExport.h" 49 "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfConfig.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfArray.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDOM.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDataDesc.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDataItem.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDataStructure.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDataTransform.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfElement.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfExpression.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfHDF.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfHDFSupport.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfHeavyData.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfInformation.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfLightData.h" 63 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfObject.h" 64 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfValues.h" 65 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfValuesBinary.h" 66 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfValuesHDF.h" 67 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfValuesXML.h" 68 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfAttribute.h" 69 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDomain.h" 70 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDsm.h" 71 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDsmBuffer.h" 72 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDsmComm.h" 73 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDsmMsg.h" 74 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfGeometry.h" 75 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfGrid.h" 76 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfH5Driver.h" 77 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfMap.h" 78 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfRegion.h" 79 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfRoot.h" 80 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfSet.h" 81 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfTime.h" 82 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfTopology.h" 86 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 88 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv5.13.so.5.13
" 89 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv5.13.so.1
" 91 if(EXISTS "${file}
" AND 92 NOT IS_SYMLINK "${file}
") 98 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 99 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkxdmf2-pv5.13.so.5.13
" 100 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkxdmf2-pv5.13.so.1
" 103 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv5.13.so.5.13
" 104 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv5.13.so.1
" 106 if(EXISTS "${file}
" AND 107 NOT IS_SYMLINK "${file}
") 110 OLD_RPATH "\$ORIGIN:
" 111 NEW_RPATH "\$ORIGIN
") 112 if(CMAKE_INSTALL_DO_STRIP) 113 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 119 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 120 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv5.13.so
" AND 121 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv5.13.so
") 123 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv5.13.so
" 126 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkxdmf2-pv5.13.so
") 127 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv5.13.so
" AND 128 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv5.13.so
") 130 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv5.13.so
" 131 OLD_RPATH "\$ORIGIN:
" 132 NEW_RPATH "\$ORIGIN
") 133 if(CMAKE_INSTALL_DO_STRIP) 134 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv5.13.so
