1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy
47  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkCompositeDataReader.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkCompositeDataWriter.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkDataObjectReader.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkDataObjectWriter.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkDataReader.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkDataSetReader.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkDataSetWriter.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkDataWriter.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkGenericDataObjectReader.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkGenericDataObjectWriter.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkGraphReader.h"
58  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkGraphWriter.h"
59  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkLegacyCellGridReader.h"
60  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkLegacyCellGridWriter.h"
61  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkPixelExtentIO.h"
62  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkPolyDataReader.h"
63  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkPolyDataWriter.h"
64  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkRectilinearGridReader.h"
65  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkRectilinearGridWriter.h"
66  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkSimplePointsReader.h"
67  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkSimplePointsWriter.h"
68  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkStructuredGridReader.h"
69  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkStructuredGridWriter.h"
70  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkStructuredPointsReader.h"
71  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkStructuredPointsWriter.h"
72  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkTableReader.h"
73  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkTableWriter.h"
74  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkTreeReader.h"
75  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkTreeWriter.h"
76  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkUnstructuredGridReader.h"
77  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkUnstructuredGridWriter.h"
78  "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Legacy/vtkIOLegacyModule.h"
79  )
80 endif()
81
82 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOLegacy-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOLegacy-hierarchy.txt")
84 endif()
85
86 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
87  foreach(file
88  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.13.so.5.13"
89  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.13.so.1"
90  )
91  if(EXISTS "${file}" AND
92  NOT IS_SYMLINK "${file}")
93  file(RPATH_CHECK
94  FILE "${file}"
95  RPATH "\$ORIGIN")
96  endif()
97  endforeach()
98  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
99  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOLegacy-pv5.13.so.5.13"
100  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOLegacy-pv5.13.so.1"
101  )
102  foreach(file
103  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.13.so.5.13"
104  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.13.so.1"
105  )
106  if(EXISTS "${file}" AND
107  NOT IS_SYMLINK "${file}")
108  file(RPATH_CHANGE
109  FILE "${file}"
110  OLD_RPATH "\$ORIGIN:"
111  NEW_RPATH "\$ORIGIN")
112  if(CMAKE_INSTALL_DO_STRIP)
113  execute_process(COMMAND "/usr/bin/strip" "${file}")
114  endif()
115  endif()
116  endforeach()
117 endif()
118
119 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
120  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.13.so" AND
121  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.13.so")
122  file(RPATH_CHECK
123  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.13.so"
124  RPATH "\$ORIGIN")
125  endif()
126  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOLegacy-pv5.13.so")
127  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.13.so" AND
128  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.13.so")
129  file(RPATH_CHANGE
130  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.13.so"
131  OLD_RPATH "\$ORIGIN:"
132  NEW_RPATH "\$ORIGIN")
133  if(CMAKE_INSTALL_DO_STRIP)
134  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.13.so")
135  endif()
136  endif()
137 endif()
138
