1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle
47  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkCameraManipulator.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkCameraManipulatorGUIHelper.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVInteractorStyle.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVJoystickFly.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVJoystickFlyIn.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVJoystickFlyOut.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballMoveActor.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballMultiRotate.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballPan.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballRoll.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballRotate.h"
58  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballEnvironmentRotate.h"
59  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballZoom.h"
60  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballZoomToMouse.h"
61  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkTrackballPan.h"
62  "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/InteractionStyle/vtkPVVTKExtensionsInteractionStyleModule.h"
63  )
64 endif()
65
66 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
67  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVVTKExtensionsInteractionStyle-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsInteractionStyle-hierarchy.txt")
68 endif()
69
70 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
71  foreach(file
72  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so.5.13"
73  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so.1"
74  )
75  if(EXISTS "${file}" AND
76  NOT IS_SYMLINK "${file}")
77  file(RPATH_CHECK
78  FILE "${file}"
79  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
80  endif()
81  endforeach()
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
83  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so.5.13"
84  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so.1"
85  )
86  foreach(file
87  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so.5.13"
88  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so.1"
89  )
90  if(EXISTS "${file}" AND
91  NOT IS_SYMLINK "${file}")
92  file(RPATH_CHANGE
93  FILE "${file}"
94  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
95  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
96  if(CMAKE_INSTALL_DO_STRIP)
97  execute_process(COMMAND "/usr/bin/strip" "${file}")
98  endif()
99  endif()
100  endforeach()
101 endif()
102
103 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
104  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so" AND
105  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so")
106  file(RPATH_CHECK
107  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so"
108  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
109  endif()
110  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so")
111  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so" AND
112  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so")
113  file(RPATH_CHANGE
114  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so"
115  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
116  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
117  if(CMAKE_INSTALL_DO_STRIP)
118  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv5.13.so")
119  endif()
120  endif()
121 endif()
122
123 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensesx" OR NOT CMAKE_INSTALL_COMPONENT)
124  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkPVVTKExtensionsInteractionStyle" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/LICENSE")
125 endif()
126
