1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Utilities/PythonInitializer
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Utilities/PythonInitializer/vtkUtilitiesPythonInitializerModule.h")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so.5.13"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so.5.13"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so.5.13"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:"
74  NEW_RPATH "\$ORIGIN")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/bin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
82 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
83  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so" AND
84  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so")
85  file(RPATH_CHECK
86  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so"
87  RPATH "\$ORIGIN")
88  endif()
89  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so")
90  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so" AND
91  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so")
92  file(RPATH_CHANGE
93  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so"
94  OLD_RPATH "\$ORIGIN:"
95  NEW_RPATH "\$ORIGIN")
96  if(CMAKE_INSTALL_DO_STRIP)
97  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInitializer-pv5.13.so")
98  endif()
99  endif()
100 endif()
101
