Labels are used to annotate Issues and Merge Requests. They help organize and provide information about their state in the development workflow.
Labels are named using the form [category]:[name]. Labels in the same category has the same color.
area:... Labels in this category identify a component of ParaView affected by the issue. Current list includes area:catalyst, area:doc, area:packaging, area:third-party, and area:web.
Reporters and developers can assign these labels to an issue to help organize.
priority:... An issue gets assigned a Milestone to indicate which release a fix for it is planned for. The priority:... label can be used to indicate how critical is this issue for that milestone.
| label | issues | merge requests | description |
priority:required | x | issue is required for a milestone (highest priority) | |
priority:important | x | issue is important for a milestone but may be okay if missed | |
priority:nice-to-have | x | issue is nice-to-have, but not critical or important | |
priority:low | x | low priority issues for a particular milestone |
If an issue targeted for a milestone has no priority label, then it is assumed the least priority.
project:... These labels are associated with Issues to identify the project/customer that wants the issue addressed. Project manager and developers working with their managers can use these labels to denote the stakeholders for a particular issue.
triage:... These labels can be assigned to Issues and Merge Requests to help triage as indicated in the table below:
triage:confirmed | x | issue has been confirmed by someone other than the reporter | |
triage:easy | x | added by developers to issues that are easy to fix | |
triage:expired | x | x | added to issues closed without resolving or merge requests closed without merging due to lack of activity |
triage:feature | x | issue is a feature request; can be added by developers or reporters | |
triage:needinfo | x | x | on an open issue, this label is added to indicate that more information is needed from the reporter; on a closed issue, this label is added to indicate that more information is needed from the developer who closed the issue about how to test or review the issue; on a merge request this label is added to request more information from the developer before the merge request can be reviewed |
triage:needswork | x | added to merge requests after review if the reviewer deems it needs more work before it can be merged | |
triage:pending-dashboards | x | added to merge requests that are awaiting dashboards before they can be reviewed or merged | |
triage:ready-for-review | x | added to merge requests that are ready for review by a developer |
These labels may be removed if the issue or merge request is no longer in the state indicated by the label. For example, a merge request gets a triage:ready-for-review label to request another developer to review it. If the reviewer deems it needs more work, he should add the triage:needswork label and remove the triage:ready-for-review label since the latter is no longer applicable.
workflow:... These labels are added to issues to indicate their state in the development cycle. Similar to priority:..., there can only be at most one workflow label on an issue at a time.
workflow:active-developement | x | added to an open issue that is under development | |
workflow:customer-review | x | added to a closed issue that is ready for review by the customer/reporter |
