VTK
ThirdParty
freetype
vtkfreetype
include
freetype
config
ftconfig.h
1
3
* ftconfig.h.in
4
5
* UNIX-specific configuration file (specification only).
6
7
* Copyright (C) 1996-2022 by
* David Turner, Robert Wilhelm, and Werner Lemberg.
9
10
* This file is part of the FreeType project, and may only be used,
11
* modified, and distributed under the terms of the FreeType project
12
* license, LICENSE.TXT. By continuing to use, modify, or distribute
13
* this file you indicate that you have read the license and
14
* understand and accept it fully.
15
16
17
18
20
21
* This header file contains a number of macro definitions that are used by
22
* the rest of the engine. Most of the macros here are automatically
23
* determined at compile time, and you should not need to change it to port
24
* FreeType, except to compile the library with a non-ANSI compiler.
25
26
* Note however that if some specific modifications are needed, we advise
27
* you to place a modified copy in your build directory.
28
* The build directory is usually `builds/<system>`, and contains
30
* system-specific files that are always included first when building the
31
* library.
32
33
35
#ifndef FTCONFIG_H_
36
#define FTCONFIG_H_
37
38
#include <ft2build.h>
#include FT_CONFIG_OPTIONS_H
40
#include FT_CONFIG_STANDARD_LIBRARY_H
41
42
#define HAVE_UNISTD_H
43
#define HAVE_FCNTL_H
45
#include <freetype/config/integer-types.h>
46
#include <freetype/config/public-macros.h>
47
#include <freetype/config/mac-support.h>
48
49
#endif
/* FTCONFIG_H_ */
50
51
52
/* END */
