3 if(
4 message(FATAL_ERROR
"CMake >= 2.6.0 required")
15 # Protect against multiple inclusion, which would fail when already imported targets are added once more.
17 set(_targetsNotDefined)
19 foreach(_expectedTarget vtkm::vectorization_flags vtkm::compiler_flags vtkm::developer_flags vtkm::optionparser vtkm::vtkmdiympi_nompi vtkm::vtkmdiy vtkm::diy_developer_flags
vtkm::diy vtkm::lcl vtkm::loguru
vtkm::cont vtkm::cont_testing vtkm::worklet vtkm::filter_core vtkm::filter vtkm::filter_clean_grid vtkm::filter_connected_components vtkm::filter_vector_analysis vtkm::filter_mesh_info vtkm::filter_contour vtkm::filter_geometry_refinement vtkm::filter_density_estimate vtkm::filter_entity_extraction vtkm::filter_field_conversion vtkm::filter_field_transform vtkm::filter_flow vtkm::filter_image_processing vtkm::filter_multi_block vtkm::filter_resampling vtkm::filter_scalar_topology vtkm::filter_zfp vtkm::lodepng vtkm::io vtkm::source)
20 list(APPEND _expectedTargets ${_expectedTarget})
21 if(NOT TARGET ${_expectedTarget})
22 list(APPEND _targetsNotDefined ${_expectedTarget})
24 if(TARGET ${_expectedTarget})
25 list(APPEND _targetsDefined ${_expectedTarget})
28 if("${_targetsDefined}
") 29 unset(_targetsDefined) 30 unset(_targetsNotDefined) 31 unset(_expectedTargets) 32 set(CMAKE_IMPORT_FILE_VERSION) 36 if(NOT "${_targetsDefined}
" STREQUAL "") 37 message(FATAL_ERROR "Some (but not all) targets in
this export
") 39 unset(_targetsDefined) 40 unset(_targetsNotDefined) 41 unset(_expectedTargets) 44 # Compute the installation prefix relative to this file. 45 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}
" PATH) 46 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 47 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 48 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 49 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 50 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 51 if(_IMPORT_PREFIX STREQUAL "/
") 52 set(_IMPORT_PREFIX "") 55 # Create imported target vtkm::vectorization_flags 56 add_library(vtkm::vectorization_flags INTERFACE IMPORTED) 58 set_target_properties(vtkm::vectorization_flags PROPERTIES 59 INTERFACE_COMPILE_OPTIONS "\$<\$<COMPILE_LANGUAGE:CXX>:>
" 62 # Create imported target vtkm::compiler_flags 63 add_library(vtkm::compiler_flags INTERFACE IMPORTED) 65 set_target_properties(vtkm::compiler_flags PROPERTIES 66 INTERFACE_COMPILE_FEATURES "cxx_std_14
" 67 INTERFACE_COMPILE_OPTIONS "\$<\$<COMPILE_LANGUAGE:CXX>:-ffunction-sections>
" 68 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-5.13/vtkvtkm/
vtk-m
" 71 # Create imported target vtkm::developer_flags 72 add_library(vtkm::developer_flags INTERFACE IMPORTED) 74 set_target_properties(vtkm::developer_flags PROPERTIES 75 INTERFACE_COMPILE_OPTIONS "\$<\$<COMPILE_LANGUAGE:CXX>:-Wall;-Wcast-align;-Wextra;-Wpointer-arith;-Wformat;-Wformat-security;-Wshadow;-Wunused;-fno-common;-Wno-unused-
function;-Wchar-subscripts;-Wfloat-conversion;-Wodr>
" 78 # Create imported target vtkm::optionparser 79 add_library(vtkm::optionparser INTERFACE IMPORTED) 81 set_target_properties(vtkm::optionparser PROPERTIES 82 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-5.13/vtkvtkm/
vtk-m/
vtkm/thirdparty/optionparser
" 85 # Create imported target vtkm::vtkmdiympi_nompi 86 add_library(vtkm::vtkmdiympi_nompi SHARED IMPORTED) 88 # Create imported target vtkm::vtkmdiy 89 add_library(vtkm::vtkmdiy INTERFACE IMPORTED) 91 set_target_properties(vtkm::vtkmdiy PROPERTIES 93 INTERFACE_COMPILE_FEATURES "cxx_std_14
" 94 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-5.13/vtkvtkm/
vtk-m/
vtkm/thirdparty/
diy/vtkmdiy/include;${_IMPORT_PREFIX}/include/paraview-5.13/vtkvtkm/
vtk-m/
vtkm/thirdparty/
diy/vtkmdiy/include/vtkmdiy/mpi
" 95 INTERFACE_LINK_LIBRARIES "vtkm::vtkmdiympi_nompi
" 96 INTERFACE_SYSTEM_INCLUDE_DIRECTORIES "include/paraview-5.13/vtkvtkm/
vtk-m/
vtkm/thirdparty/
diy/vtkmdiy/include;include/paraview-5.13/vtkvtkm/
vtk-m/
vtkm/thirdparty/
" 99 # Create imported target vtkm::diy_developer_flags 100 add_library(vtkm::diy_developer_flags INTERFACE IMPORTED) 102 set_target_properties(vtkm::diy_developer_flags PROPERTIES 103 INTERFACE_COMPILE_OPTIONS "\$<\$<COMPILE_LANGUAGE:CXX>:-Wall;-Wcast-align;-Wchar-subscripts;-Wextra;-Wpointer-arith;-Wformat;-Wformat-security;-Wshadow;-Wunused;-fno-common;-Wfloat-conversion;-Wno-sign-conversion;-Wno-sign-compare;-Wno-cast-align;-Wodr>
" 106 # Create imported target vtkm::diy 107 add_library(vtkm::diy INTERFACE IMPORTED) 109 set_target_properties(vtkm::diy PROPERTIES 110 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-5.13/vtkvtkm/
vtk-m/
vtkm/thirdparty/
diy" 111 INTERFACE_LINK_LIBRARIES "vtkm::vtkmdiy;vtkm::vtkmdiympi_nompi
" 114 # Create imported target vtkm::lcl 115 add_library(vtkm::lcl INTERFACE IMPORTED) 117 set_target_properties(vtkm::lcl PROPERTIES 118 INTERFACE_COMPILE_FEATURES "cxx_std_11
" 119 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-5.13/vtkvtkm/
vtk-m/
vtkm/thirdparty/lcl/vtkmlcl
" 122 # Create imported target vtkm::loguru 123 add_library(vtkm::loguru INTERFACE IMPORTED) 125 set_target_properties(vtkm::loguru PROPERTIES 126 INTERFACE_COMPILE_FEATURES "cxx_std_11
" 127 INTERFACE_LINK_LIBRARIES "dl;Threads::Threads
" 130 # Create imported target vtkm::cont 131 add_library(vtkm::cont SHARED IMPORTED) 133 set_target_properties(vtkm::cont PROPERTIES 134 INTERFACE_LINK_LIBRARIES "vtkm::optionparser;
vtkm::diy;vtkm::lcl;vtkm::compiler_flags;Threads::Threads
" 137 # Create imported target vtkm::cont_testing 138 add_library(vtkm::cont_testing SHARED IMPORTED) 140 set_target_properties(vtkm::cont_testing PROPERTIES 144 # Create imported target vtkm::worklet 145 add_library(vtkm::worklet SHARED IMPORTED) 147 set_target_properties(vtkm::worklet PROPERTIES 151 # Create imported target vtkm::filter_core 152 add_library(vtkm::filter_core SHARED IMPORTED) 154 set_target_properties(vtkm::filter_core PROPERTIES 155 INTERFACE_LINK_LIBRARIES "vtkm::cont;vtkm::worklet
" 158 # Create imported target vtkm::filter 159 add_library(vtkm::filter INTERFACE IMPORTED) 161 set_target_properties(vtkm::filter PROPERTIES 162 INTERFACE_LINK_LIBRARIES "vtkm::filter_core;vtkm::filter_clean_grid;vtkm::filter_connected_components;vtkm::filter_vector_analysis;vtkm::filter_mesh_info;vtkm::filter_contour;vtkm::filter_geometry_refinement;vtkm::filter_density_estimate;vtkm::filter_entity_extraction;vtkm::filter_field_conversion;vtkm::filter_field_transform;vtkm::filter_flow;vtkm::filter_image_processing;vtkm::filter_multi_block;vtkm::filter_resampling;vtkm::filter_scalar_topology;vtkm::filter_zfp
" 165 # Create imported target vtkm::filter_clean_grid 166 add_library(vtkm::filter_clean_grid SHARED IMPORTED) 168 set_target_properties(vtkm::filter_clean_grid PROPERTIES 169 INTERFACE_LINK_LIBRARIES "vtkm::filter_core
" 172 # Create imported target vtkm::filter_connected_components 173 add_library(vtkm::filter_connected_components SHARED IMPORTED) 175 set_target_properties(vtkm::filter_connected_components PROPERTIES 176 INTERFACE_LINK_LIBRARIES "vtkm::filter_core;vtkm::filter_core
" 179 # Create imported target vtkm::filter_vector_analysis 180 add_library(vtkm::filter_vector_analysis SHARED IMPORTED) 182 set_target_properties(vtkm::filter_vector_analysis PROPERTIES 183 INTERFACE_LINK_LIBRARIES "vtkm::filter_core
" 186 # Create imported target vtkm::filter_mesh_info 187 add_library(vtkm::filter_mesh_info SHARED IMPORTED) 189 set_target_properties(vtkm::filter_mesh_info PROPERTIES 190 INTERFACE_LINK_LIBRARIES "vtkm::filter_core
" 193 # Create imported target vtkm::filter_contour 194 add_library(vtkm::filter_contour SHARED IMPORTED) 196 set_target_properties(vtkm::filter_contour PROPERTIES 197 INTERFACE_LINK_LIBRARIES "vtkm::filter_core;vtkm::filter_vector_analysis;vtkm::filter_mesh_info
" 200 # Create imported target vtkm::filter_geometry_refinement 201 add_library(vtkm::filter_geometry_refinement SHARED IMPORTED) 203 set_target_properties(vtkm::filter_geometry_refinement PROPERTIES 204 INTERFACE_LINK_LIBRARIES "vtkm::filter_core;vtkm::worklet;vtkm::filter_core
" 207 # Create imported target vtkm::filter_density_estimate 208 add_library(vtkm::filter_density_estimate SHARED IMPORTED) 210 set_target_properties(vtkm::filter_density_estimate PROPERTIES 211 INTERFACE_LINK_LIBRARIES "vtkm::filter_core
" 214 # Create imported target vtkm::filter_entity_extraction 215 add_library(vtkm::filter_entity_extraction SHARED IMPORTED) 217 set_target_properties(vtkm::filter_entity_extraction PROPERTIES 218 INTERFACE_LINK_LIBRARIES "vtkm::filter_core;vtkm::filter_clean_grid
" 221 # Create imported target vtkm::filter_field_conversion 222 add_library(vtkm::filter_field_conversion SHARED IMPORTED) 224 set_target_properties(vtkm::filter_field_conversion PROPERTIES 225 INTERFACE_LINK_LIBRARIES "vtkm::filter_core
" 228 # Create imported target vtkm::filter_field_transform 229 add_library(vtkm::filter_field_transform SHARED IMPORTED) 231 set_target_properties(vtkm::filter_field_transform PROPERTIES 232 INTERFACE_LINK_LIBRARIES "vtkm::filter_core;vtkm::worklet;vtkm::filter_core
" 235 # Create imported target vtkm::filter_flow 236 add_library(vtkm::filter_flow SHARED IMPORTED) 238 set_target_properties(vtkm::filter_flow PROPERTIES 239 INTERFACE_LINK_LIBRARIES "vtkm::filter_core
" 242 # Create imported target vtkm::filter_image_processing 243 add_library(vtkm::filter_image_processing SHARED IMPORTED) 245 set_target_properties(vtkm::filter_image_processing PROPERTIES 246 INTERFACE_LINK_LIBRARIES "vtkm::filter_core
" 249 # Create imported target vtkm::filter_multi_block 250 add_library(vtkm::filter_multi_block SHARED IMPORTED) 252 set_target_properties(vtkm::filter_multi_block PROPERTIES 253 INTERFACE_LINK_LIBRARIES "vtkm::filter_core
" 256 # Create imported target vtkm::filter_resampling 257 add_library(vtkm::filter_resampling SHARED IMPORTED) 259 set_target_properties(vtkm::filter_resampling PROPERTIES 260 INTERFACE_LINK_LIBRARIES "vtkm::filter_core;vtkm::filter_density_estimate;vtkm::filter_entity_extraction
" 263 # Create imported target vtkm::filter_scalar_topology 264 add_library(vtkm::filter_scalar_topology SHARED IMPORTED) 266 set_target_properties(vtkm::filter_scalar_topology PROPERTIES 267 INTERFACE_LINK_LIBRARIES "vtkm::filter_core;vtkm::worklet;vtkm::filter_core
" 270 # Create imported target vtkm::filter_zfp 271 add_library(vtkm::filter_zfp SHARED IMPORTED) 273 set_target_properties(vtkm::filter_zfp PROPERTIES 274 INTERFACE_LINK_LIBRARIES "vtkm::filter_core
" 277 # Create imported target vtkm::lodepng 278 add_library(vtkm::lodepng INTERFACE IMPORTED) 280 # Create imported target vtkm::io 281 add_library(vtkm::io SHARED IMPORTED) 283 set_target_properties(vtkm::io PROPERTIES 284 INTERFACE_LINK_LIBRARIES "vtkm::cont
" 287 # Create imported target vtkm::source 288 add_library(vtkm::source SHARED IMPORTED) 290 set_target_properties(vtkm::source PROPERTIES 291 INTERFACE_LINK_LIBRARIES "vtkm::cont;vtkm::filter_field_conversion;vtkm::filter_multi_block
" 294 if(CMAKE_VERSION VERSION_LESS 3.0.0) 295 message(FATAL_ERROR "This file relies
on consumers
using CMake 3.0.0 or greater.
") 298 # Load information for each installed configuration. 299 get_filename_component(_DIR "${CMAKE_CURRENT_LIST_FILE}
" PATH) 300 file(GLOB CONFIG_FILES "${_DIR}/VTKmTargets-*.cmake
") 301 foreach(f ${CONFIG_FILES}) 305 # Cleanup temporary variables. 308 # Loop over all imported files and verify that they actually exist 309 foreach(target ${_IMPORT_CHECK_TARGETS} ) 310 foreach(file ${_IMPORT_CHECK_FILES_FOR_${target}} ) 311 if(NOT EXISTS "${file}
" ) 312 message(FATAL_ERROR "The imported
target \
"${target}\" references the file 314 but this file does not exist. Possible reasons include: 315 * The file was deleted, renamed, or moved to another location. 316 * An install or uninstall procedure did not complete successfully. 317 * The installation package was faulty and contained 318 \"${CMAKE_CURRENT_LIST_FILE}\" 319 but not all the files it references. 323 unset(_IMPORT_CHECK_FILES_FOR_${
target})
325 unset(_IMPORT_CHECK_TARGETS)
327 # This file does not depend on other imported targets which have 328 # been exported from the same project but in a separate export set. 330 # Commands beyond this point should not need to know the version. 331 set(CMAKE_IMPORT_FILE_VERSION)
#define VTKMDIY_NO_THREADS
#define VTKMDIY_MPI_AS_LIB
