1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m
47  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkmstd/cmake_install.cmake")
48 endif()
49
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51  # Include the install script for the subdirectory.
52  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/thirdparty/optionparser/cmake_install.cmake")
53 endif()
54
55 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
56  # Include the install script for the subdirectory.
57  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/thirdparty/diy/cmake_install.cmake")
58 endif()
59
60 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
61  # Include the install script for the subdirectory.
62  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/thirdparty/lcl/cmake_install.cmake")
63 endif()
64
65 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
66  # Include the install script for the subdirectory.
67  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/thirdparty/loguru/cmake_install.cmake")
68 endif()
69
70 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
71  # Include the install script for the subdirectory.
72  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/cmake_install.cmake")
73 endif()
74
75 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
76  # Include the install script for the subdirectory.
77  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/cuda/cmake_install.cmake")
78 endif()
79
80 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
81  # Include the install script for the subdirectory.
82  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/kokkos/cmake_install.cmake")
83 endif()
84
85 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
86  # Include the install script for the subdirectory.
87  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/openmp/cmake_install.cmake")
88 endif()
89
90 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
91  # Include the install script for the subdirectory.
92  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/serial/cmake_install.cmake")
93 endif()
94
95 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
96  # Include the install script for the subdirectory.
97  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/tbb/cmake_install.cmake")
98 endif()
99
100 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
101  # Include the install script for the subdirectory.
102  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/testlib/cmake_install.cmake")
103 endif()
104
105 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
106  # Include the install script for the subdirectory.
107  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/cmake_install.cmake")
108 endif()
109
110 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
111  # Include the install script for the subdirectory.
112  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/cuda/cmake_install.cmake")
113 endif()
114
115 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
116  # Include the install script for the subdirectory.
117  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/kokkos/cmake_install.cmake")
118 endif()
119
120 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
121  # Include the install script for the subdirectory.
122  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/openmp/cmake_install.cmake")
123 endif()
124
125 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
126  # Include the install script for the subdirectory.
127  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/serial/cmake_install.cmake")
128 endif()
129
130 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
131  # Include the install script for the subdirectory.
132  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/exec/tbb/cmake_install.cmake")
133 endif()
134
135 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
136  # Include the install script for the subdirectory.
137  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/worklet/cmake_install.cmake")
138 endif()
139
140 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
141  # Include the install script for the subdirectory.
142  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/cmake_install.cmake")
143 endif()
144
145 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
146  # Include the install script for the subdirectory.
147  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/clean_grid/cmake_install.cmake")
148 endif()
149
150 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
151  # Include the install script for the subdirectory.
152  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/connected_components/cmake_install.cmake")
153 endif()
154
155 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
156  # Include the install script for the subdirectory.
157  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/vector_analysis/cmake_install.cmake")
158 endif()
159
160 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
161  # Include the install script for the subdirectory.
162  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/mesh_info/cmake_install.cmake")
163 endif()
164
165 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
166  # Include the install script for the subdirectory.
167  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/contour/cmake_install.cmake")
168 endif()
169
170 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
171  # Include the install script for the subdirectory.
172  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/geometry_refinement/cmake_install.cmake")
173 endif()
174
175 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
176  # Include the install script for the subdirectory.
177  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/density_estimate/cmake_install.cmake")
178 endif()
179
180 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
181  # Include the install script for the subdirectory.
182  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/entity_extraction/cmake_install.cmake")
183 endif()
184
185 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
186  # Include the install script for the subdirectory.
187  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/field_conversion/cmake_install.cmake")
188 endif()
189
190 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
191  # Include the install script for the subdirectory.
192  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/field_transform/cmake_install.cmake")
193 endif()
194
195 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
196  # Include the install script for the subdirectory.
197  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/flow/cmake_install.cmake")
198 endif()
199
200 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
201  # Include the install script for the subdirectory.
202  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/image_processing/cmake_install.cmake")
203 endif()
204
205 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
206  # Include the install script for the subdirectory.
207  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/multi_block/cmake_install.cmake")
208 endif()
209
210 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
211  # Include the install script for the subdirectory.
212  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/resampling/cmake_install.cmake")
213 endif()
214
215 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
216  # Include the install script for the subdirectory.
217  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/scalar_topology/cmake_install.cmake")
218 endif()
219
220 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
221  # Include the install script for the subdirectory.
222  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/zfp/cmake_install.cmake")
223 endif()
224
225 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
226  # Include the install script for the subdirectory.
227  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/interop/cmake_install.cmake")
228 endif()
229
230 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
231  # Include the install script for the subdirectory.
232  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/thirdparty/lodepng/cmake_install.cmake")
233 endif()
234
235 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
236  # Include the install script for the subdirectory.
237  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/cmake_install.cmake")
238 endif()
239
240 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
241  # Include the install script for the subdirectory.
242  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/random/cmake_install.cmake")
243 endif()
244
245 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
246  # Include the install script for the subdirectory.
247  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/source/cmake_install.cmake")
248 endif()
249
250 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
251  # Include the install script for the subdirectory.
252  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cmake_install.cmake")
253 endif()
254
255 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
256  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkvtkm" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/config/vtkm_config.mk")
257 endif()
258
259 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
260  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkvtkm" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/config/vtkm.pc")
261 endif()
262
263 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
264  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkvtkm" TYPE FILE RENAME "VTKmREADME.md" FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/README.md")
265 endif()
266
267 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
268  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkvtkm" TYPE FILE RENAME "VTKmLICENSE.txt" FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/LICENSE.txt")
269 endif()
270
271 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
272  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/vtk/vtkm" TYPE FILE FILES
273  "/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-5.13/vtk/vtkm/VTKmConfig.cmake"
274  "/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-5.13/vtk/vtkm/VTKmConfigVersion.cmake"
275  )
276 endif()
277
278 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
279  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/vtk/vtkm/cmake" TYPE FILE FILES
280  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMake/VTKmCMakeBackports.cmake"
281  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMake/FindTBB.cmake"
282  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMake/patches/FindMPI.cmake"
283  )
284 endif()
285
286 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
287  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/vtk/vtkm/cmake/3.15" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMake/patches/3.15/FindMPI.cmake")
288 endif()
289
290 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
291  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/vtk/vtkm/cmake" TYPE FILE FILES
292  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMake/VTKmCPUVectorization.cmake"
293  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMake/VTKmDetectCUDAVersion.cu"
294  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMake/VTKmDeviceAdapters.cmake"
295  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMake/VTKmDIYUtils.cmake"
296  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMake/VTKmExportHeaderTemplate.h.in"
297  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMake/VTKmRenderingContexts.cmake"
298  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMake/VTKmWrappers.cmake"
299  )
300 endif()
301
302 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
303  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/vtk/vtkm/VTKmTargets.cmake")
304  file(DIFFERENT EXPORT_FILE_CHANGED FILES
305  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/vtk/vtkm/VTKmTargets.cmake"
306  "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMakeFiles/Export/lib64/cmake/paraview-5.13/vtk/vtkm/VTKmTargets.cmake")
307  if(EXPORT_FILE_CHANGED)
308  file(GLOB OLD_CONFIG_FILES "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/vtk/vtkm/VTKmTargets-*.cmake")
309  if(OLD_CONFIG_FILES)
310  message(STATUS "Old export file \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/vtk/vtkm/VTKmTargets.cmake\" will be replaced. Removing files [${OLD_CONFIG_FILES}].")
311  file(REMOVE ${OLD_CONFIG_FILES})
312  endif()
313  endif()
314  endif()
315  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/vtk/vtkm" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMakeFiles/Export/lib64/cmake/paraview-5.13/vtk/vtkm/VTKmTargets.cmake")
316  if("${CMAKE_INSTALL_CONFIG_NAME}" MATCHES "^([Dd][Ee][Bb][Uu][Gg])$")
317  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/vtk/vtkm" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMakeFiles/Export/lib64/cmake/paraview-5.13/vtk/vtkm/VTKmTargets-debug.cmake")
318  endif()
319 endif()
320
321 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
322  # Include the install script for the subdirectory.
323  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/examples/cmake_install.cmake")
324 endif()
325
