1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/DigitalRockPhysics 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
"/builds/gitlab-kitware-sciviz-ci/build/Plugins/DigitalRockPhysics/Filters/cmake_install.cmake")
50 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 51 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/DigitalRockPhysics-targets.cmake
") 52 file(DIFFERENT EXPORT_FILE_CHANGED FILES 53 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/DigitalRockPhysics-targets.cmake
" 54 "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DigitalRockPhysics/CMakeFiles/Export/lib64/cmake/paraview-5.13/DigitalRockPhysics-targets.cmake
") 55 if(EXPORT_FILE_CHANGED) 56 file(GLOB OLD_CONFIG_FILES "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/DigitalRockPhysics-targets-*.cmake
") 58 message(STATUS "Old export file \
"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/DigitalRockPhysics-targets.cmake\" will be replaced. Removing files [${OLD_CONFIG_FILES}].")
59 file(REMOVE ${OLD_CONFIG_FILES})
63 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DigitalRockPhysics/CMakeFiles/Export/lib64/cmake/paraview-5.13/DigitalRockPhysics-targets.cmake
") 64 if("${CMAKE_INSTALL_CONFIG_NAME}
" MATCHES "^([Dd][Ee][Bb][Uu][Gg])$
") 65 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DigitalRockPhysics/CMakeFiles/Export/lib64/cmake/paraview-5.13/DigitalRockPhysics-targets-debug.cmake
") 69 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 70 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13
" TYPE FILE RENAME "DigitalRockPhysics-
vtk-module-properties.cmake
" FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DigitalRockPhysics/CMakeFiles/DigitalRockPhysics-
vtk-module-properties.cmake.install
") 73 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 74 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkDigitalRocksFiltersCS.a
") 77 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xpluginsx
" OR NOT CMAKE_INSTALL_COMPONENT) 78 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalRockPhysics/DigitalRockPhysics.so
" AND 79 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalRockPhysics/DigitalRockPhysics.so
") 81 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalRockPhysics/DigitalRockPhysics.so
" 82 RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 84 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalRockPhysics
" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/DigitalRockPhysics/DigitalRockPhysics.so
") 85 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalRockPhysics/DigitalRockPhysics.so
" AND 86 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalRockPhysics/DigitalRockPhysics.so
") 88 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalRockPhysics/DigitalRockPhysics.so
" 89 OLD_RPATH "/builds/gitlab-kitware-sciviz-ci/build/lib64:/usr/lib64/openmpi/lib:/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/DigitalRockPhysics:
" 90 NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 91 if(CMAKE_INSTALL_DO_STRIP) 92 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalRockPhysics/DigitalRockPhysics.so
