1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/ParaView_paraview_plugins" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel/vtkArrayDispatchDSPArrayList.h" 48 "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel/vtkMultiDimensionalArray.h" 49 "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel/vtkMultiDimensionalImplicitBackend.h" 50 "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel/vtkDSPDataModelModule.h" 54 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 55 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalSignalProcessing/
vtk/hierarchy/DigitalSignalProcessing
" TYPE FILE RENAME "vtkDSPDataModel-hierarchy.txt
" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/DigitalSignalProcessing/
vtk/hierarchy/DigitalSignalProcessing/vtkDSPDataModel-hierarchy.txt
") 58 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xpluginsx
" OR NOT CMAKE_INSTALL_COMPONENT) 59 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalSignalProcessing
" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/DigitalSignalProcessing/libvtkDSPDataModel.a
