4 This file is used by CMake when finding VTK. It provides the [VTK module
5 API][] as well as some VTK-specific APIs.
7 The following variables are provided by
this module:
13 * `VTK_AVAILABLE_COMPONENTS`: Components available with VTK.
14 * `VTK_PREFIX_PATH`: Install prefix
for VTK.
15 * `VTK_LEGACY_REMOVE`: Whether VTK
's deprecated APIs are 17 * `VTK_HAS_VTKm`: If VTK provides VTK-m. 18 * `VTK_OPENGL_HAS_EGL`: If VTK::opengl uses EGL. Only provided if the 19 `VTK::opengl` target exists. 20 * `VTK_OPENGL_HAS_OSMESA`: If VTK::opengl uses OSMESA. Only provided if the 21 `VTK::opengl` target exists. 22 * `VTK_USE_X`: If VTK uses X windows. Only provided if the 23 `VTK::opengl` target exists. 24 * `VTK_PYTHON_VERSION`: The major version of Python used by VTK. Empty if 25 Python support is not available. 26 * `VTK_WRAP_PYTHON`: If VTK itself provides Python wrapping. If so, the 27 Python parts of the module API are available. 28 * `VTK_WRAP_JAVA`: If VTK itself provides Java wrapping. If so, the 29 Java parts of the module API are available. 30 * `VTK_WRAP_SERIALIZATION`: If VTK itself provides serialization wrappings 31 for marshallable classes in modules with `INCLUDE_MARSHAL`. 32 * `VTK_PYTHONPATH`: Where VTK's Python modules live inside the install
33 prefix. Unset
if Python is not available.
34 * `VTK_LIBRARIES`: The list of modules specified by `COMPONENTS` and
35 `OPTIONAL_COMPONENTS`. However,
if no components are specified, all
36 available components are added to
this variable. This may be used in
37 `MODULES` arguments in the API (e.g., `vtk_module_autoinit`). All modules
38 are also targets and may be linked to
using `target_link_libraries`.
39 * `VTK_AUTOINIT_INCLUDE`: The header to include
for access to VTK
's autoinit 41 * `VTK_QT_VERSION`: The major version of Qt used by VTK if Qt support enabled. 42 * `VTK_QML_DIR`: Where VTK's QML plugins live
if QML support is
enabled.
43 * `VTK_ENABLE_VR_COLLABORATION`: Is VR collaboration
enabled when VR is
enabled.
44 * `VTK_SMP_BACKENDS`: The list of available SMP backends.
46 For more information about the Python in use by VTK, (note that the `Python`
47 component must be found to guarantee that
this happens), see the
48 [FindPython3][] documentation
for what is available. Of particular use are
51 - the `Python3_VERSION` variable; and
52 - the `Python3::Python`
target.
58 if (CMAKE_VERSION VERSION_LESS
"3.12")
59 set(
"${CMAKE_FIND_PACKAGE_NAME}_FOUND" 0)
60 set(
"${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE" 61 "VTK requires CMake 3.12 in order to reliably be used.")
68 set("${CMAKE_FIND_PACKAGE_NAME}_AVAILABLE_COMPONENTS
" "WrappingTools;WebPython;WebCore;WebGLExporter;PythonInterpreter;ViewsContext2D;ViewsCore;RenderingUI;loguru;cli11;TestingRendering;ImagingColor;TestingCore;RenderingVolumeAMR;RenderingVolumeOpenGL2;RenderingParallelLIC;RenderingParallel;RenderingMatplotlib;RenderingLabel;octree;RenderingLICOpenGL2;RenderingContextOpenGL2;RenderingCellGrid;ImagingMath;ParallelMPI4Py;mpi4py;ImagingFourier;IOXdmf2;IOXMLParser;libxml2;
xdmf2;IOVeraOut;IOVPIC;vpic;IOTecplotTable;utf8;IOTRUCHAS;IOSegY;IOParallelXML;IOParallelNetCDF;IOParallelLSDyna;IOLSDyna;IOParallelExodus;IOExodus;exodusII;IOPLY;IOPIO;IOOggTheora;theora;ogg;IOOMF;IONetCDF;libproj;IOParallel;IOMPIImage;IOImport;IOIOSS;ioss;IOH5part;h5part;IOH5Rage;IOFLUENTCFF;IOMovie;IOFDS;IOInfovis;InfovisCore;IOExportGL2PS;RenderingGL2PSOpenGL2;gl2ps;png;netcdf;IOEnSight;IOERF;IOCityGML;IOChemistry;IOCONVERGECFD;IOHDF;IOCGNSReader;cgns;IOAsynchronous;IOExport;RenderingVtkJS;libharu;IOGeometry;RenderingSceneGraph;jsoncpp;IOAMR;hdf5;GeovisCore;sqlite;GUISupportQt;InteractionWidgets;RenderingVolume;RenderingAnnotation;InteractionStyle;ImagingHybrid;FiltersTensor;FiltersTemporal;FiltersPython;FiltersProgrammable;FiltersPoints;FiltersParallelVerdict;FiltersParallelStatistics;FiltersParallelGeometry;FiltersParallelFlowPaths;FiltersParallelDIY2;ParallelDIY;FiltersImaging;ImagingGeneral;FiltersGeometryPreview;FiltersGeneric;FiltersFlowPaths;eigen;FiltersAMR;FiltersParallelMPI;FiltersParallel;FiltersTexture;FiltersModeling;ParallelMPI;mpi;DomainsChemistryOpenGL2;RenderingOpenGL2;RenderingHyperTreeGrid;glew;opengl;FiltersHybrid;DomainsChemistry;WrappingPythonCore;Python;ChartsCore;FiltersExtraction;diy2;IOXML;expat;ParallelCore;IOLegacy;IOCellGrid;FiltersCellGrid;token;IOCore;lzma;fast_float;lz4;FiltersStatistics;FiltersHyperTree;ImagingSources;IOImage;DICOMParser;jpeg;metaio;tiff;RenderingContext2D;RenderingFreeType;freetype;kwiml;zlib;RenderingCore;FiltersSources;CommonColor;AcceleratorsVTKmFilters;AcceleratorsVTKmCore;AcceleratorsVTKmDataModel;ImagingCore;FiltersGeneral;fmt;FiltersVerdict;verdict;FiltersGeometry;CommonComputationalGeometry;FiltersCore;FiltersReduction;CommonExecutionModel;vtkvtkm;CommonDataModel;pegtl;pugixml;CommonSystem;CommonMisc;exprtk;CommonTransforms;CommonMath;kissfft;CommonCore;doubleconversion;nlohmannjson;
vtksys;WrapHierarchy;WrapPython;WrapPythonInit;ParseJava;WrapJava
") 70 set(_vtk_temp_variables) 71 set(_vtk_real_components) 72 foreach (_vtk_component IN LISTS "${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS
") 73 # Handle component requests that are not VTK. 74 if (NOT _vtk_component IN_LIST "${CMAKE_FIND_PACKAGE_NAME}_AVAILABLE_COMPONENTS
") 75 set("${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
" 0) 76 list(APPEND "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_NOT_FOUND_MESSAGE
" 77 "The ${_vtk_component}
component is not recognized.
") 79 if (_vtk_component MATCHES "^
vtk" AND 80 NOT _vtk_component STREQUAL "vtksys" AND 81 NOT _vtk_component STREQUAL "vtkjava
") 82 string(SUBSTRING "${_vtk_component}
" 3 -1 _vtk_actual_component) 83 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_FIND_VERSION) 84 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_FIND_QUIETLY) 87 "'${_vtk_actual_component}'") 89 elseif (${CMAKE_FIND_PACKAGE_NAME}_FIND_VERSION VERSION_LESS "8.90
") 90 # Ignore for compatibility. 94 "'${_vtk_actual_component}'. By requesting at least
version 8.90, the
" 97 list(APPEND _vtk_real_components 98 "${_vtk_actual_component}
") 99 list(APPEND _vtk_temp_variables 100 "${CMAKE_FIND_PACKAGE_NAME}_FIND_REQUIRED_${_vtk_actual_component}
") 101 set("${CMAKE_FIND_PACKAGE_NAME}_FIND_REQUIRED_${_vtk_actual_component}
" 102 "${${CMAKE_FIND_PACKAGE_NAME}_FIND_REQUIRED_${_vtk_component}}
") 103 unset(_vtk_actual_component) 105 list(APPEND _vtk_real_components 109 unset(_vtk_component) 110 set("${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS
" 111 ${_vtk_real_components}) 112 unset(_vtk_real_components) 114 set("${CMAKE_FIND_PACKAGE_NAME}_CMAKE_MODULE_PATH_save
" "${CMAKE_MODULE_PATH}
") 115 list(INSERT CMAKE_MODULE_PATH 0 116 "${CMAKE_CURRENT_LIST_DIR}
") 118 set("${CMAKE_FIND_PACKAGE_NAME}_CMAKE_PREFIX_PATH_save
" "${CMAKE_PREFIX_PATH}
") 119 include("${CMAKE_CURRENT_LIST_DIR}/
vtk-prefix.cmake
") 120 set("${CMAKE_FIND_PACKAGE_NAME}_PREFIX_PATH
" 121 "${_vtk_module_import_prefix}
") 122 unset(_vtk_module_import_prefix) 123 list(INSERT CMAKE_PREFIX_PATH 0 124 "${${CMAKE_FIND_PACKAGE_NAME}_PREFIX_PATH}
") 126 set("${CMAKE_FIND_PACKAGE_NAME}_VERSION
" "9.3.20240617
") 127 set("${CMAKE_FIND_PACKAGE_NAME}_MAJOR_VERSION
" "9
") 128 set("${CMAKE_FIND_PACKAGE_NAME}_MINOR_VERSION
" "3
") 129 set("${CMAKE_FIND_PACKAGE_NAME}_BUILD_VERSION
" "20240617
") 130 set("${CMAKE_FIND_PACKAGE_NAME}_LEGACY_REMOVE
" "OFF
") 131 set("${CMAKE_FIND_PACKAGE_NAME}_AUTOINIT_INCLUDE
"vtkAutoInit.h\"")
132 set(
"${CMAKE_FIND_PACKAGE_NAME}_SMP_BACKENDS" "STDThread;Sequential")
134 unset("${CMAKE_FIND_PACKAGE_NAME}_FOUND
") 135 set("${CMAKE_FIND_PACKAGE_NAME}_HAS_VTKm
" "ON
") 136 if (${CMAKE_FIND_PACKAGE_NAME}_HAS_VTKm) 138 PATHS "${CMAKE_CURRENT_LIST_DIR}/
vtkm" 141 set("${CMAKE_FIND_PACKAGE_NAME}_FOUND
" 0) 144 # Prior to VTK-m 2.0, the main VTK module was called VTK::vtkm 145 if (TARGET VTK::vtkvtkm) 146 add_library(VTK::vtkm ALIAS VTK::vtkvtkm) 150 include("${CMAKE_CURRENT_LIST_DIR}/vtkCMakeBackports.cmake
") 151 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}-targets.cmake
") 152 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}-
vtk-module-properties.cmake
") 154 include("${CMAKE_CURRENT_LIST_DIR}/
vtk-find-package-helpers.cmake
" OPTIONAL) 156 # Ensure that the right OpenGL preference is in place when finding the OpenGL 158 if (1) # vtk_opengl_preference_set 159 if (DEFINED OpenGL_GL_PREFERENCE) 160 set("${CMAKE_FIND_PACKAGE_NAME}_OpenGL_GL_PREFERENCE_save
" "${OpenGL_GL_PREFERENCE}
") 162 set(OpenGL_GL_PREFERENCE "GLVND
") 165 # Ensure that python is found based on location, not on version 166 # See https://cmake.org/cmake/help/latest/module/FindPython.html 167 if (DEFINED Python3_FIND_STRATEGY) 168 set("${CMAKE_FIND_PACKAGE_NAME}_Python3_FIND_STRATEGY_save
" "${Python3_FIND_STRATEGY}
") 170 set(Python3_FIND_STRATEGY LOCATION) 172 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}-
vtk-module-find-packages.cmake
") 174 if (1) # vtk_opengl_preference_set 175 if (DEFINED "${CMAKE_FIND_PACKAGE_NAME}_OpenGL_GL_PREFERENCE_save
") 176 set(OpenGL_GL_PREFERENCE "${${CMAKE_FIND_PACKAGE_NAME}_OpenGL_GL_PREFERENCE_save}
") 177 unset("${CMAKE_FIND_PACKAGE_NAME}_OpenGL_GL_PREFERENCE_save
") 179 unset(OpenGL_GL_PREFERENCE) 183 if (DEFINED "${CMAKE_FIND_PACKAGE_NAME}_Python3_FIND_STRATEGY_save
") 184 set(Python3_FIND_STRATEGY "${${CMAKE_FIND_PACKAGE_NAME}_Python3_FIND_STRATEGY_save}
") 185 unset("${CMAKE_FIND_PACKAGE_NAME}_Python3_FIND_STRATEGY_save
") 187 unset(Python3_FIND_STRATEGY) 190 if (TARGET VTK::opengl) 191 set(VTK_OPENGL_HAS_EGL "OFF
") 192 set(VTK_OPENGL_HAS_OSMESA "OFF
") 196 if (TARGET VTK::RenderingVR) 197 set("${CMAKE_FIND_PACKAGE_NAME}_ENABLE_VR_COLLABORATION
" "") 200 if (5) # VTK_QT_VERSION 201 set("${CMAKE_FIND_PACKAGE_NAME}_QT_VERSION
" "5
") 205 set("${CMAKE_FIND_PACKAGE_NAME}_QML_DIR
" "${${CMAKE_FIND_PACKAGE_NAME}_PREFIX_PATH}/
") 208 include("${CMAKE_CURRENT_LIST_DIR}/vtkModule.cmake
") 209 include("${CMAKE_CURRENT_LIST_DIR}/vtkEncodeString.cmake
") 210 include("${CMAKE_CURRENT_LIST_DIR}/vtkHashSource.cmake
") 213 include("${CMAKE_CURRENT_LIST_DIR}/vtkModuleJson.cmake
") 215 set("${CMAKE_FIND_PACKAGE_NAME}_PYTHON_VERSION
" "3
") 216 set("${CMAKE_FIND_PACKAGE_NAME}_WRAP_PYTHON
" "ON
") 217 if (${CMAKE_FIND_PACKAGE_NAME}_WRAP_PYTHON) 218 include("${CMAKE_CURRENT_LIST_DIR}/VTKPython-targets.cmake
") 219 include("${CMAKE_CURRENT_LIST_DIR}/vtkmodules-
vtk-python-module-properties.cmake
") 220 include("${CMAKE_CURRENT_LIST_DIR}/vtkModuleWrapPython.cmake
") 221 set("${CMAKE_FIND_PACKAGE_NAME}_PYTHONPATH
" "lib64/python3.10/site-packages
") 224 set("${CMAKE_FIND_PACKAGE_NAME}_WRAP_JAVA
" "") 225 if (${CMAKE_FIND_PACKAGE_NAME}_WRAP_JAVA) 226 include("${CMAKE_CURRENT_LIST_DIR}/vtkModuleWrapJava.cmake
") 228 if () # VTK_JAVA_JOGL_COMPONENT 229 set(_vtk_find_jogl_args) 230 if (${CMAKE_FIND_PACKAGE_NAME}_FIND_QUIETLY) 231 list(APPEND _vtk_find_jogl_args QUIET) 233 find_package(JOGL ${_vtk_find_jogl_args}) 234 unset(_vtk_find_jogl_args) 237 include("${CMAKE_CURRENT_LIST_DIR}/VTKJava-targets.cmake
") 238 set("${CMAKE_FIND_PACKAGE_NAME}_vtkjava_FOUND
" 1) 240 set("${CMAKE_FIND_PACKAGE_NAME}_vtkjava_FOUND
" 0) 241 set("${CMAKE_FIND_PACKAGE_NAME}_vtkjava_NOT_FOUND_MESSAGE
" 242 "JOGL was not found
") 247 set("${CMAKE_FIND_PACKAGE_NAME}_WRAP_SERIALIZATION
" "OFF
") 248 include("${CMAKE_CURRENT_LIST_DIR}/vtkModuleSerialization.cmake
") 250 set(_vtk_search_components 251 ${${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS}) 252 if (NOT _vtk_search_components) 253 set(_vtk_search_components 254 ${${CMAKE_FIND_PACKAGE_NAME}_AVAILABLE_COMPONENTS}) 256 list(REMOVE_ITEM _vtk_search_components 257 # These components need to always be requested explicitly since they are 259 WrapHierarchy;vtkpython;pvtkpython;WrapPython;WrapPythonInit;vtkjava;ParseJava;WrapJava) 260 set(_vtk_components_to_check) 261 foreach (_vtk_component IN LISTS _vtk_search_components) 262 if (DEFINED "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
") 263 # It was already not-found (likely due to `find-package` failures). 264 elseif (TARGET "${CMAKE_FIND_PACKAGE_NAME}::${_vtk_component}
") 265 list(APPEND _vtk_components_to_check 268 set("${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
" 0) 269 list(APPEND "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_NOT_FOUND_MESSAGE
" 270 "The ${_vtk_component}
component is not available.
") 273 unset(_vtk_component) 274 unset(_vtk_search_components) 276 while (_vtk_components_to_check) 277 list(GET _vtk_components_to_check 0 _vtk_component) 278 list(REMOVE_AT _vtk_components_to_check 0) 279 if (DEFINED "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
") 280 # We've already made a determiniation. 284 get_property(_vtk_public_dependencies 285 TARGET "${CMAKE_FIND_PACKAGE_NAME}::${_vtk_component}
" 286 PROPERTY "INTERFACE_vtk_module_depends
") 287 get_property(_vtk_private_dependencies 288 TARGET "${CMAKE_FIND_PACKAGE_NAME}::${_vtk_component}
" 289 PROPERTY "INTERFACE_vtk_module_private_depends
") 290 get_property(_vtk_optional_dependencies 291 TARGET "${CMAKE_FIND_PACKAGE_NAME}::${_vtk_component}
" 292 PROPERTY "INTERFACE_vtk_module_optional_depends
") 293 set(_vtk_dependencies 294 ${_vtk_public_dependencies} 295 ${_vtk_private_dependencies}) 296 foreach (_vtk_optional_dependency IN LISTS _vtk_optional_dependencies) 297 if (TARGET "${_vtk_optional_dependency}
") 298 list(APPEND _vtk_dependencies 299 "${_vtk_optional_dependency}
") 302 unset(_vtk_public_dependencies) 303 unset(_vtk_private_dependencies) 304 unset(_vtk_optional_dependency) 305 unset(_vtk_optional_dependencies) 307 string(REPLACE "${CMAKE_FIND_PACKAGE_NAME}::
" "" _vtk_dependencies "${_vtk_dependencies}
") 308 set(_vtk_all_dependencies_checked TRUE) 309 foreach (_vtk_dependency IN LISTS _vtk_dependencies) 310 if (DEFINED "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_dependency}_FOUND
") 311 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_${_vtk_dependency}_FOUND) 312 set("${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
" 0) 313 list(APPEND "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_NOT_FOUND_MESSAGE
" 314 "Failed to find the ${_vtk_dependency}
component.
") 317 # Check its dependencies. 318 list(APPEND _vtk_components_to_check 319 "${_vtk_dependency}
") 320 set(_vtk_all_found FALSE) 323 if (NOT DEFINED "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
") 324 if (_vtk_all_dependencies_checked) 325 set("${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
" 1) 327 list(APPEND _vtk_components_to_check 331 unset(_vtk_all_dependencies_checked) 332 unset(_vtk_dependency) 333 unset(_vtk_dependencies) 335 unset(_vtk_component) 336 unset(_vtk_components_to_check) 338 set(_vtk_missing_components) 339 foreach (_vtk_component IN LISTS "${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS
") 340 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND AND ${CMAKE_FIND_PACKAGE_NAME}_FIND_REQUIRED_${_vtk_component}) 341 list(APPEND _vtk_missing_components 346 if (_vtk_missing_components) 347 list(REMOVE_DUPLICATES _vtk_missing_components) 348 list(SORT _vtk_missing_components) 349 string(REPLACE ";
" _vtk_missing_components "${_vtk_missing_components}
") 350 set("${CMAKE_FIND_PACKAGE_NAME}_FOUND
" 0) 351 set("${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE
" 352 "Could not find the ${CMAKE_FIND_PACKAGE_NAME}
package with the following required components: ${_vtk_missing_components}.")
354 unset(_vtk_missing_components)
356 set("${CMAKE_FIND_PACKAGE_NAME}_LIBRARIES")
357 if (NOT DEFINED "${CMAKE_FIND_PACKAGE_NAME}_FOUND")
358 # If nothing went wrong, we've successfully found the package.
359 set("${CMAKE_FIND_PACKAGE_NAME}_FOUND" 1)
360 set(_vtk_found_components
361 ${${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS})
362 if (NOT _vtk_found_components)
363 set(_vtk_found_components
364 ${${CMAKE_FIND_PACKAGE_NAME}_AVAILABLE_COMPONENTS})
366 list(REMOVE_ITEM _vtk_found_components
367 # These components need to always be requested explicitly since they are
369 WrapHierarchy;vtkpython;pvtkpython;WrapPython;WrapPythonInit;vtkjava;ParseJava;WrapJava)
370 # Build the `_LIBRARIES` variable.
371 foreach (_vtk_component IN LISTS _vtk_found_components)
372 if (TARGET
"${CMAKE_FIND_PACKAGE_NAME}::${_vtk_component}")
373 list(APPEND
"${CMAKE_FIND_PACKAGE_NAME}_LIBRARIES" 374 "${CMAKE_FIND_PACKAGE_NAME}::${_vtk_component}")
377 unset(_vtk_component)
378 unset(_vtk_found_components)
381 set(CMAKE_PREFIX_PATH "${${CMAKE_FIND_PACKAGE_NAME}_CMAKE_PREFIX_PATH_save}
") 382 unset("${CMAKE_FIND_PACKAGE_NAME}_CMAKE_PREFIX_PATH_save
") 384 set(CMAKE_MODULE_PATH "${${CMAKE_FIND_PACKAGE_NAME}_CMAKE_MODULE_PATH_save}
") 385 unset("${CMAKE_FIND_PACKAGE_NAME}_CMAKE_MODULE_PATH_save
") 387 foreach (_vtk_temp_variable IN LISTS _vtk_temp_variables) 388 unset("${_vtk_temp_variable}
") 390 unset(_vtk_temp_variable) 391 unset(_vtk_temp_variables) 393 # Compatibility with old code. 394 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_FIND_VERSION) 395 set(VTK_USE_FILE "${CMAKE_CURRENT_LIST_DIR}/
vtk-use-file-deprecated.cmake
") 396 elseif (${CMAKE_FIND_PACKAGE_NAME}_FIND_VERSION VERSION_LESS "8.90
") 397 set(VTK_USE_FILE "${CMAKE_CURRENT_LIST_DIR}/
vtk-use-file-compat.cmake
") 399 set(VTK_USE_FILE "${CMAKE_CURRENT_LIST_DIR}/
vtk-use-file-error.cmake
#define VTK_BUILD_VERSION
#define VTK_MINOR_VERSION
#define VTK_MAJOR_VERSION
