ParaViewTestInstall.cmake
1 # SPDX-FileCopyrightText: Copyright (c) Kitware Inc.
2 # SPDX-FileCopyrightText: Copyright (c) Sandia Corporation
3 # SPDX-License-Identifier: BSD-3-Clause
4
5 #
6 # This script tests the ParaView install tree by building the examples
7 #
8 # The script expects the following input variables:
9 # PARAVIEW_BINARY_DIR : Build path for ParaView (To run 'make install' here)
10 # PARAVIEW_INSTALL_DIR : Install path for ParaView Examples are built against
11 # (This should be CMAKE_INSTALL_PREFIX set for ParaView)
12 # PARAVIEW_SOURCE_DIR : ParaView source dir (For source location of Examples)
13 # PARAVIEW_TEST_DIR : Temporary directory for location of Examples build tree
14 # PARAVIEW_VERSION : ParaView version string used when creating the installtree
15
16 message (STATUS "Building Examples against ParaView install tree")
17 message("CTEST_FULL_OUTPUT") # Don't truncate test output.
18 # Remove the drive letter from `PARAVIEW_INSTALL_DIR` so we can append it to
19 # DESTDIR safely.
20 if (WIN32 AND IS_ABSOLUTE "${PARAVIEW_INSTALL_DIR}")
21  string(REGEX REPLACE "^.:" "" PARAVIEW_INSTALL_DIR "${PARAVIEW_INSTALL_DIR}")
22 endif ()
23 set (paraview_prefix
24  $ENV{DESTDIR}${PARAVIEW_INSTALL_DIR})
25 set (ParaView_DIR
26  ${paraview_prefix}/${PARAVIEW_CMAKE_DESTINATION})
27 if (WIN32)
28  set(ENV{PATH}
29  "$ENV{PATH};${paraview_prefix}/${PARAVIEW_BINDIR}")
30 endif ()
31 message(STATUS "ParaView_DIR: ${ParaView_DIR}")
32
33 # Build target "INSTALL" for paraview
34 if (MSVC)
35  set (install_tgt "INSTALL")
36  set (opt "/maxcpucount")
37 else ()
38  set (install_tgt "install")
39  set (opt "-j5")
40 endif ()
41 execute_process (COMMAND ${CMAKE_COMMAND}
42  --build ${PARAVIEW_BINARY_DIR}
43  --target ${install_tgt}
44  -- ${opt}
45  WORKING_DIRECTORY ${PARAVIEW_BINARY_DIR}
46  RESULT_VARIABLE irv)
47 if (NOT irv EQUAL 0)
48  message(FATAL_ERROR "Could not build target 'install' for ParaView")
49 endif ()
50
51 set(generator_args)
52 if (CMAKE_GENERATOR)
53  list(APPEND generator_args
54  -G "${CMAKE_GENERATOR}")
55 endif ()
56 if (CMAKE_GENERATOR_PLATFORM)
57  list(APPEND generator_args
58  -A "${CMAKE_GENERATOR_PLATFORM}")
59 endif ()
60 if (CMAKE_GENERATOR_TOOLSET)
61  list(APPEND generator_args
62  -T "${CMAKE_GENERATOR_TOOLSET}")
63 endif ()
64
65 set (INSTALL_TEST_BUILD_DIR ${PARAVIEW_TEST_DIR}/Examples-bld)
66 if (NOT EXISTS ${INSTALL_TEST_BUILD_DIR})
67  file(MAKE_DIRECTORY
68  ${INSTALL_TEST_BUILD_DIR})
69 endif ()
70 execute_process (
71  COMMAND ${CMAKE_COMMAND}
72  ${generator_args}
73  -DParaView_DIR:PATH=${ParaView_DIR}
74  -DBUILD_SHARED_LIBS:BOOL=${BUILD_SHARED_LIBS}
75  -DCMAKE_BUILD_TYPE:STRING=${CMAKE_BUILD_TYPE}
76  ${PARAVIEW_SOURCE_DIR}/Examples
77  WORKING_DIRECTORY ${INSTALL_TEST_BUILD_DIR}
78  RESULT_VARIABLE crv)
79 if (NOT crv EQUAL 0)
80  message(FATAL_ERROR "Configuration failed with return code ${crv}")
81 endif ()
82 execute_process (
83  COMMAND ${CMAKE_COMMAND} --build ${INSTALL_TEST_BUILD_DIR} --clean-first
84  WORKING_DIRECTORY ${INSTALL_TEST_BUILD_DIR}
85  RESULT_VARIABLE rv)
86 if (NOT rv EQUAL 0)
87  message(FATAL_ERROR "Build failed with return code ${rv}")
88 endif ()
target
boost::graph_traits< vtkGraph * >::vertex_descriptor target(boost::graph_traits< vtkGraph * >::edge_descriptor e, vtkGraph *)
