1 if (NOT (DEFINED paraview_cmake_dir AND
2 DEFINED paraview_cmake_build_dir AND
3 DEFINED paraview_cmake_destination AND
4 DEFINED paraview_modules))
6 "ParaViewInstallCMakePackage is missing input variables.")
9 _vtk_module_write_import_prefix("${paraview_cmake_build_dir}/paraview-prefix.cmake
" "${paraview_cmake_destination}
11 set(paraview_has_catalyst 0)
12 set(paraview_catalyst_directory "")
13 if (TARGET ParaView::catalyst-paraview)
14 set(paraview_has_catalyst 1)
15 get_property(paraview_catalyst_directory GLOBAL
16 PROPERTY paraview_catalyst_directory)
19 string(REPLACE "ParaView::
" "" _paraview_all_components "${paraview_modules};${paraview_client_modules}
22 "${paraview_cmake_dir}/paraview-config.cmake.in
23 "${paraview_cmake_build_dir}/paraview-config.cmake
25 include(CMakePackageConfigHelpers)
26 write_basic_package_version_file("${paraview_cmake_build_dir}/paraview-config-
version.cmake
27 VERSION "${PARAVIEW_VERSION_FULL}
28 COMPATIBILITY AnyNewerVersion)
30 # For convenience, a package is written to the top of the build tree. At some
31 # point, this should probably be deprecated and warn when it is used.
33 OUTPUT "${CMAKE_BINARY_DIR}/paraview-config.cmake
34 CONTENT "include(\
"${paraview_cmake_build_dir}/paraview-config.cmake\")\n")
36 "${paraview_cmake_build_dir}/paraview-config-
version.cmake
37 "${CMAKE_BINARY_DIR}/paraview-config-
version.cmake
40 set(paraview_cmake_module_files
42 paraview-use-file-compat.cmake
43 paraview-use-file-deprecated.cmake
44 paraview-use-file-error.cmake
47 paraview_client_initializer.cxx.in
48 paraview_client_initializer.h.in
49 paraview_client_main.cxx.in
51 paraview_servermanager_convert_categoryindex.xsl
52 paraview_servermanager_convert_html.xsl
53 paraview_servermanager_convert_wiki.xsl.in
54 paraview_servermanager_convert_xml.xsl
57 paraview_plugin.cxx.in
60 pqActionGroupImplementation.cxx.in
61 pqActionGroupImplementation.h.in
62 pqAutoStartImplementation.cxx.in
63 pqAutoStartImplementation.h.in
64 pqDockWindowImplementation.cxx.in
65 pqDockWindowImplementation.h.in
66 pqGraphLayoutStrategyImplementation.cxx.in
67 pqGraphLayoutStrategyImplementation.h.in
68 pqPluginLocationImplementation.cxx.in
69 pqPluginLocationImplementation.h.in
70 pqPropertyWidgetInterface.cxx.in
71 pqPropertyWidgetInterface.h.in
72 pqServerManagerModelImplementation.cxx.in
73 pqServerManagerModelImplementation.h.in
74 pqToolBarImplementation.cxx.in
75 pqToolBarImplementation.h.in
76 pqTreeLayoutStrategyImplementation.cxx.in
77 pqTreeLayoutStrategyImplementation.h.in
80 ParaViewServerManager.cmake
86 vtkModuleWrapClientServer.cmake
89 ParaViewTranslations.cmake
90 XML_translations_header_generator.py)
92 # From the `GmshIO` plugin.
93 if (TARGET GmshIO::vtkGmshIO)
94 list(APPEND paraview_cmake_module_files
98 set(paraview_cmake_files_to_install)
99 foreach (paraview_cmake_module_file IN LISTS paraview_cmake_module_files)
101 "${paraview_cmake_dir}/${paraview_cmake_module_file}
102 "${paraview_cmake_build_dir}/${paraview_cmake_module_file}
104 list(APPEND paraview_cmake_files_to_install
105 "${paraview_cmake_module_file}
108 if (PARAVIEW_ENABLE_VISITBRIDGE)
109 set(paraview_visitbridge_cmake_module_files
115 foreach (paraview_cmake_module_file IN LISTS paraview_visitbridge_cmake_module_files)
117 "${ParaView_SOURCE_DIR}/Utilities/VisItBridge/databases/cmake/${paraview_cmake_module_file}
118 "${paraview_cmake_build_dir}/${paraview_cmake_module_file}
120 list(APPEND paraview_cmake_files_to_install
121 "${paraview_cmake_build_dir}/${paraview_cmake_module_file}
125 include(ParaViewInstallCMakePackageHelpers)
126 if (NOT PARAVIEW_RELOCATABLE_INSTALL)
127 list(APPEND paraview_cmake_files_to_install
128 "${paraview_cmake_build_dir}/paraview-find-package-helpers.cmake
131 foreach (paraview_cmake_file IN LISTS paraview_cmake_files_to_install)
132 if (IS_ABSOLUTE "${paraview_cmake_file}
133 file(RELATIVE_PATH paraview_cmake_subdir_root "${paraview_cmake_build_dir}
" "${paraview_cmake_file}
134 get_filename_component(paraview_cmake_subdir "${paraview_cmake_subdir_root}
" DIRECTORY)
135 set(paraview_cmake_original_file "${paraview_cmake_file}
137 get_filename_component(paraview_cmake_subdir "${paraview_cmake_file}
" DIRECTORY)
138 set(paraview_cmake_original_file "${paraview_cmake_dir}/${paraview_cmake_file}
141 FILES "${paraview_cmake_original_file}
142 DESTINATION "${paraview_cmake_destination}/${paraview_cmake_subdir}
143 COMPONENT "development
147 FILES "${paraview_cmake_build_dir}/paraview-config.cmake
148 "${paraview_cmake_build_dir}/paraview-config-
version.cmake
149 "${paraview_cmake_build_dir}/paraview-prefix.cmake
150 DESTINATION "${paraview_cmake_destination}
151 COMPONENT "development
153 vtk_module_export_find_packages(
154 CMAKE_DESTINATION "${paraview_cmake_destination}
155 FILE_NAME "ParaView-
vtk-module-find-packages.cmake
156 MODULES ${paraview_modules})
158 vtk_module_export_find_packages(
159 CMAKE_DESTINATION "${paraview_cmake_destination}
160 FILE_NAME "ParaViewIncubator-
161 MODULES ${paraview_incubator_modules})
164 get_property(paraview_client_xml_files GLOBAL
165 PROPERTY paraview_client_xml_files)
166 get_property(paraview_client_xml_destination GLOBAL
167 PROPERTY paraview_client_xml_destination)
169 set(cmake_xml_file_name "ParaView-client-xml.cmake
170 set(cmake_xml_build_file "${paraview_cmake_build_dir}/${cmake_xml_file_name}
171 set(cmake_xml_install_file "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${cmake_xml_file_name}.install
173 file(WRITE "${cmake_xml_build_file}
174 file(WRITE "${cmake_xml_install_file}
175 _vtk_module_write_import_prefix("${cmake_xml_install_file}
" "${paraview_client_xml_destination}
176 file(APPEND "${cmake_xml_build_file}
177 "set(\
"\${CMAKE_FIND_PACKAGE_NAME}_CLIENT_XML_FILES\")\n")
178 file(APPEND "${cmake_xml_install_file}
179 "set(\
181 foreach (paraview_client_xml_file IN LISTS paraview_client_xml_files)
182 get_filename_component(basename "${paraview_client_xml_file}
" NAME)
183 file(APPEND "${cmake_xml_build_file}
184 "list(APPEND \
185 \"${paraview_client_xml_file}\")\n")
186 file(APPEND
"${cmake_xml_install_file}"
187 "list(APPEND \"\${CMAKE_FIND_PACKAGE_NAME}_CLIENT_XML_FILES\"
188 \"\${_vtk_module_import_prefix}/${paraview_client_xml_destination}/${basename}\")\n")
192 FILES "${cmake_xml_install_file}
193 DESTINATION "${paraview_cmake_destination}
194 RENAME "${cmake_xml_file_name}
195 COMPONENT "development
