3 if(NOT PARAVIEW_DATA_STORE)
4 # Select a default from the following.
5 set(PARAVIEW_DATA_STORE_DEFAULT
6 if(EXISTS
"${ParaView_SOURCE_DIR}/.ExternalData/config/store")
7 # Configuration left by developer setup script.
8 file(STRINGS
9 PARAVIEW_DATA_STORE_DEFAULT LIMIT_COUNT 1 LIMIT_INPUT 1024)
10 elseif(IS_DIRECTORY
"${CMAKE_SOURCE_DIR}/../ParaViewExternalData")
11 # Adjacent directory created by user.
12 get_filename_component(PARAVIEW_DATA_STORE_DEFAULT
13 "${CMAKE_SOURCE_DIR}/../ParaViewExternalData" ABSOLUTE)
14 elseif(IS_DIRECTORY
"${CMAKE_SOURCE_DIR}/../ExternalData")
15 # Generic adjacent directory created by user.
16 get_filename_component(PARAVIEW_DATA_STORE_DEFAULT
17 "${CMAKE_SOURCE_DIR}/../ExternalData" ABSOLUTE)
18 elseif(DEFINED
"ENV{ParaViewExternalData_OBJECT_STORES}")
19 # The ParaViewExternalData environment variable.
20 file(TO_CMAKE_PATH
"$ENV{ParaViewExternalData_OBJECT_STORES}" PARAVIEW_DATA_STORE_DEFAULT)
21 elseif(DEFINED
"ENV{ExternalData_OBJECT_STORES}")
22 # Generic ExternalData environment variable.
23 file(TO_CMAKE_PATH
"$ENV{ExternalData_OBJECT_STORES}" PARAVIEW_DATA_STORE_DEFAULT)
27 # Provide users with an option to select a local object store,
28 # starting with the above-selected default.
29 set(PARAVIEW_DATA_STORE
"${PARAVIEW_DATA_STORE_DEFAULT}" CACHE PATH
30 "Local directory holding ExternalData objects in the layout %(algo)/%(hash).")
31 mark_as_advanced(PARAVIEW_DATA_STORE)
33 # Use a store in the build tree if none is otherwise configured.
34 if(NOT PARAVIEW_DATA_STORE)
35 if(ExternalData_OBJECT_STORES)
36 set(PARAVIEW_DATA_STORE
38 set(PARAVIEW_DATA_STORE
"${CMAKE_BINARY_DIR}/ExternalData/Objects")
39 file(MAKE_DIRECTORY
"${PARAVIEW_DATA_STORE}")
43 # Tell ExternalData module about selected object stores.
44 list(APPEND ExternalData_OBJECT_STORES
45 # Store selected by ParaView-specific configuration above.
46 ${PARAVIEW_DATA_STORE}
48 # Local data store populated by the ParaView pre-commit hook
49 "${CMAKE_SOURCE_DIR}/.ExternalData"
52 set(ExternalData_BINARY_ROOT ${CMAKE_BINARY_DIR}/ExternalData)
54 set(ExternalData_URL_TEMPLATES
"" CACHE STRING
55 "Additional URL templates for the ExternalData CMake script to look for testing data. E.g.
56 file:///var/bigharddrive/%(algo)/%(hash)")
57 mark_as_advanced(ExternalData_URL_TEMPLATES)
58 list(APPEND ExternalData_URL_TEMPLATES
59 # Data published by Girder
60 "https://data.kitware.com/api/v1/file/hashsum/%(algo)/%(hash)/download"
62 # Data published by developers
using git-gitlab-push
63 "https://www.paraview.org/files/ExternalData/%(algo)/%(hash)"
66 # Tell ExternalData commands to transform raw files to content links.
67 # TODO: Condition this feature on presence of our pre-commit hook.
68 set(ExternalData_LINK_CONTENT SHA512)
70 # Match series of the form <base>.<ext>, <base>_<n>.<ext> such that <base> may
71 # end in a (test) number that is not part of any series numbering.
72 set(ExternalData_SERIES_PARSE
73 set(ExternalData_SERIES_MATCH
"(_[0-9]+)?")
75 if(DEFINED ENV{DASHBOARD_TEST_FROM_CTEST})
76 # Dashboard builds always need
data.
77 set(PARAVIEW_DATA_EXCLUDE_FROM_ALL OFF)
80 if(NOT DEFINED PARAVIEW_DATA_EXCLUDE_FROM_ALL)
81 if(EXISTS "${ParaView_SOURCE_DIR}/.ExternalData/config/exclude-from-all
82 # Configuration left by developer setup script.
83 file(STRINGS "${ParaView_SOURCE_DIR}/.ExternalData/config/exclude-from-all
84 PARAVIEW_DATA_EXCLUDE_FROM_ALL_DEFAULT LIMIT_COUNT 1 LIMIT_INPUT 1024)
85 elseif(DEFINED "ENV{PARAVIEW_DATA_EXCLUDE_FROM_ALL}
86 set(PARAVIEW_DATA_EXCLUDE_FROM_ALL_DEFAULT
87 "$ENV{PARAVIEW_DATA_EXCLUDE_FROM_ALL}
89 set(PARAVIEW_DATA_EXCLUDE_FROM_ALL_DEFAULT OFF)
91 set(PARAVIEW_DATA_EXCLUDE_FROM_ALL "${PARAVIEW_DATA_EXCLUDE_FROM_ALL_DEFAULT}
92 CACHE BOOL "Exclude test
data download from
default 'all' target.
94 mark_as_advanced(PARAVIEW_DATA_EXCLUDE_FROM_ALL)
97 # Tell VTK to act as we do but not to warn when we warn.
98 set(VTK_DATA_EXCLUDE_FROM_ALL ${PARAVIEW_DATA_EXCLUDE_FROM_ALL})
99 set(VTK_DATA_EXCLUDE_FROM_ALL_NO_WARNING 1)
