The Extrusion Surface representation can now process 3-component vector array as input data. If such an input is selected, it will be treated as a displacement on the GPU (see image below).
The option Recalcuate Normals has also been added in order to compute the surface normals after the extrusion to prevent bad visual results due to flat surface (for example with a plane).
1.8.13 on Wed Dec 17 2025
