ParaView 6.0.1 Release Notes
Bug fixes made since ParaView 6.0.0 are listed below:
Faulty default color map in ParaView 6.0.0 fixed
The "Fast" color map, which is the new default in ParaView 6.0.0, was not correctly defined in the ParaView 6.0.0 release. Its color space was set to "Diverging" rather than "Lab". As a result, the central lightest point in the color map was shifted to the left of center and was too bright.
Incorrect vs. correct Fast color map
Comparison of incorrect "Fast" color map in ParaView 6.0.0 (upper legend) vs. corrected "Fast" color map in ParaView 6.0.1 (lower legend).
The "Fast" color map has been corrected in ParaView 6.0.1. If you need to produce images with the same color map as ParaView 6.0.0, you can either:
In addition, the "Fast", "Fast (Reds)", and "Fast (Blues)" color map presets were set to have the color space "RGB" instead of "Lab". Fortunately, the differences between these color maps interpolated through "RGB" and "Lab" spaces respectively is not perceptually noticable in any of them, though there are slight RGB color differences.
<img src="img/6.0.1/FastColorMapRGBvsLab.png" alt=""Fast" color map color space comparison"/>
Comparison of "Fast" color map in RGB color space (ParaView 6.0.0 preset, upper legend) vs. Lab color space (ParaView 6.0.1 preset, lower legend).
<img src="img/6.0.1/FastRedsColorMapRGBvsLab.png" alt=""Fast (Reds)" color map color space comparison"/>
Comparison of "Fast (Reds)" color map in RGB color space (ParaView 6.0.0 preset, upper legend) vs. Lab color space (ParaView 6.0.1 preset, lower legend).
<img src="img/6.0.1/FastBluesColorMapRGBvsLab.png" alt=""Fast (Blues)" color map color space comparison"/>
Comparison of "Fast (Blues)" color map in RGB color space (ParaView 6.0.0 preset, upper legend) vs. Lab color space (ParaView 6.0.1 preset, lower legend).
Interface improvements
Rendering
Readers
Filters
Catalyst
Python
Build
