Prism-targets.cmake
1 # Generated by CMake
4  message(FATAL_ERROR "CMake >= 2.8.3 required")
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "2.8.3")
7  message(FATAL_ERROR "CMake >= 2.8.3 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 2.8.3...3.30)
14
17
22 foreach(_cmake_expected_target IN ITEMS Prism::vtkPrismFilters Prism::vtkPrismViews Prism::vtkPrismServerManager Prism::vtkPrismReaders)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Create imported target Prism::vtkPrismFilters
50 add_library(Prism::vtkPrismFilters SHARED IMPORTED)
51
52 set_target_properties(Prism::vtkPrismFilters PROPERTIES
53  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Filters"
54  INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel"
55 )
56
57 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
58  target_sources(Prism::vtkPrismFilters
59  INTERFACE
60  FILE_SET "vtk_module_templates"
61  TYPE "HEADERS"
62  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters"
63  FILES
64  INTERFACE
65  FILE_SET "vtk_module_headers"
66  TYPE "HEADERS"
67  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters"
68  FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters/vtkPrismGeometryConverter.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters/vtkSimulationPointCloudFilter.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters/vtkSimulationToPrismFilter.h"
69  INTERFACE
70  FILE_SET "vtk_module_nowrap_headers"
71  TYPE "HEADERS"
72  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters"
73  FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Filters/vtkPrismFiltersModule.h"
74  )
75 else()
76  set_property(TARGET Prism::vtkPrismFilters
77  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
78  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters"
79  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters"
80  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters"
81  )
82 endif()
83
84 # Create imported target Prism::vtkPrismViews
85 add_library(Prism::vtkPrismViews SHARED IMPORTED)
86
87 set_target_properties(Prism::vtkPrismViews PROPERTIES
88  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Views;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Views;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Views"
89  INTERFACE_LINK_LIBRARIES "ParaView::RemotingViews;VTK::CommonExecutionModel;VTK::PythonUsed"
90 )
91
92 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
93  target_sources(Prism::vtkPrismViews
94  INTERFACE
95  FILE_SET "vtk_module_templates"
96  TYPE "HEADERS"
97  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views"
98  FILES
99  INTERFACE
100  FILE_SET "vtk_module_headers"
101  TYPE "HEADERS"
102  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views"
103  FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views/vtkPrismGeometryRepresentation.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views/vtkPrismGeometryRepresentationWithFaces.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views/vtkPrismSelectionRepresentation.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views/vtkPrismView.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views/vtkSMPrismViewProxy.h"
104  INTERFACE
105  FILE_SET "vtk_module_nowrap_headers"
106  TYPE "HEADERS"
107  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views"
108  FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Views/vtkPrismViewsModule.h"
109  )
110 else()
111  set_property(TARGET Prism::vtkPrismViews
112  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
113  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views"
114  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views"
115  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views"
116  )
117 endif()
118
119 # Create imported target Prism::vtkPrismServerManager
120 add_library(Prism::vtkPrismServerManager SHARED IMPORTED)
121
122 set_target_properties(Prism::vtkPrismServerManager PROPERTIES
123  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/ServerManager;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/ServerManager;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/ServerManager"
124  INTERFACE_LINK_LIBRARIES "ParaView::RemotingServerManager;VTK::CommonExecutionModel;VTK::PythonUsed"
125 )
126
127 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
128  target_sources(Prism::vtkPrismServerManager
129  INTERFACE
130  FILE_SET "vtk_module_templates"
131  TYPE "HEADERS"
132  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager"
133  FILES
134  INTERFACE
135  FILE_SET "vtk_module_headers"
136  TYPE "HEADERS"
137  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager"
138  FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager/vtkSMPrismIsSimulationDataDomain.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager/vtkSMPrismTableArraysDomain.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager/vtkSMPrismThresholdRangeDomain.h"
139  INTERFACE
140  FILE_SET "vtk_module_nowrap_headers"
141  TYPE "HEADERS"
142  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager"
143  FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/ServerManager/vtkPrismServerManagerModule.h"
144  )
145 else()
146  set_property(TARGET Prism::vtkPrismServerManager
147  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
148  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager"
149  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager"
150  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager"
151  )
152 endif()
153
154 # Create imported target Prism::vtkPrismReaders
155 add_library(Prism::vtkPrismReaders SHARED IMPORTED)
156
157 set_target_properties(Prism::vtkPrismReaders PROPERTIES
158  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Readers;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Readers;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Readers"
159  INTERFACE_LINK_LIBRARIES "ParaView::VTKExtensionsIOCore;Prism::vtkPrismServerManager;VTK::CommonExecutionModel;VTK::PythonUsed"
160 )
161
162 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
163  target_sources(Prism::vtkPrismReaders
164  INTERFACE
165  FILE_SET "vtk_module_templates"
166  TYPE "HEADERS"
167  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers"
168  FILES
169  INTERFACE
170  FILE_SET "vtk_module_headers"
171  TYPE "HEADERS"
172  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers"
173  FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers/vtkPrismSESAMEFileSeriesReader.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers/vtkPrismSESAMEReader.h"
174  INTERFACE
175  FILE_SET "vtk_module_nowrap_headers"
176  TYPE "HEADERS"
177  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers"
178  FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Readers/vtkPrismReadersModule.h"
179  )
180 else()
181  set_property(TARGET Prism::vtkPrismReaders
182  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
183  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers"
184  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers"
185  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers"
186  )
187 endif()
188
189 # Import target "Prism::vtkPrismFilters" for configuration "Release"
190 set_property(TARGET Prism::vtkPrismFilters APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
191 set_target_properties(Prism::vtkPrismFilters PROPERTIES
192  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonCore;VTK::CommonDataModel;VTK::FiltersCore;VTK::FiltersGeneral;VTK::fmt"
193  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/Prism/libvtkPrismFilters.so"
194  IMPORTED_SONAME_RELEASE "libvtkPrismFilters.so"
195  )
196
197 # Import target "Prism::vtkPrismViews" for configuration "Release"
198 set_property(TARGET Prism::vtkPrismViews APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
199 set_target_properties(Prism::vtkPrismViews PROPERTIES
200  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::RemotingCore;Prism::vtkPrismFilters;VTK::CommonCore;VTK::CommonDataModel;VTK::FiltersExtraction;VTK::FiltersGeometry"
201  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/Prism/libvtkPrismViews.so"
202  IMPORTED_SONAME_RELEASE "libvtkPrismViews.so"
203  )
204
205 # Import target "Prism::vtkPrismServerManager" for configuration "Release"
206 set_property(TARGET Prism::vtkPrismServerManager APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
207 set_target_properties(Prism::vtkPrismServerManager PROPERTIES
208  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::RemotingCore;VTK::CommonCore;VTK::CommonDataModel"
209  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/Prism/libvtkPrismServerManager.so"
210  IMPORTED_SONAME_RELEASE "libvtkPrismServerManager.so"
211  )
212
213 # Import target "Prism::vtkPrismReaders" for configuration "Release"
214 set_property(TARGET Prism::vtkPrismReaders APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
215 set_target_properties(Prism::vtkPrismReaders PROPERTIES
216  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonMisc;VTK::FiltersGeometry"
217  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/Prism/libvtkPrismReaders.so"
218  IMPORTED_SONAME_RELEASE "libvtkPrismReaders.so"
219  )
220
221 # Make sure the targets which have been exported in some other
222 # export set exist.
223 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
224 foreach(_target "VTK::CommonExecutionModel" "ParaView::RemotingViews" "VTK::PythonUsed" "ParaView::RemotingServerManager" "ParaView::VTKExtensionsIOCore" )
225  if(NOT TARGET "${_target}" )
226  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
227  endif()
228 endforeach()
229
230 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
231  if(CMAKE_FIND_PACKAGE_NAME)
232  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
233  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
234  else()
235  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
236  endif()
237 endif()
238 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
239
240 # Commands beyond this point should not need to know the version.
241 set(CMAKE_IMPORT_FILE_VERSION)
242 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:20
