GeodesicMeasurement-targets.cmake
1 # Generated by CMake
4  message(FATAL_ERROR "CMake >= 2.8.3 required")
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "2.8.3")
7  message(FATAL_ERROR "CMake >= 2.8.3 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 2.8.3...3.30)
14
17
22 foreach(_cmake_expected_target IN ITEMS GeodesicMeasurement::GeodesicMeasurementFilters GeodesicMeasurement::FmmMesh)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Create imported target GeodesicMeasurement::GeodesicMeasurementFilters
50 add_library(GeodesicMeasurement::GeodesicMeasurementFilters SHARED IMPORTED)
51
52 set_target_properties(GeodesicMeasurement::GeodesicMeasurementFilters PROPERTIES
53  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/GeodesicMeasurement/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/GeodesicMeasurement/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/GeodesicMeasurement/Filters"
54  INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel"
55 )
56
57 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
58  target_sources(GeodesicMeasurement::GeodesicMeasurementFilters
59  INTERFACE
60  FILE_SET "vtk_module_templates"
61  TYPE "HEADERS"
62  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters"
63  FILES
64  INTERFACE
65  FILE_SET "vtk_module_headers"
66  TYPE "HEADERS"
67  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters"
68  FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/vtkFastMarchingGeodesicDistance.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/vtkFastMarchingGeodesicPath.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/vtkGeodesicsBetweenPoints.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/vtkPolyDataGeodesicDistance.h"
69  INTERFACE
70  FILE_SET "vtk_module_nowrap_headers"
71  TYPE "HEADERS"
72  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters"
73  FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/GeodesicMeasurement/Filters/vtkGeodesicMeasurementFiltersModule.h"
74  )
75 else()
76  set_property(TARGET GeodesicMeasurement::GeodesicMeasurementFilters
77  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
78  "/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters"
79  "/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters"
80  "/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters"
81  )
82 endif()
83
84 # Create imported target GeodesicMeasurement::FmmMesh
85 add_library(GeodesicMeasurement::FmmMesh STATIC IMPORTED)
86
87 set_target_properties(GeodesicMeasurement::FmmMesh PROPERTIES
88  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/GeodesicMeasurement/Filters/FmmMesh;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/FmmMesh;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/FmmMesh/gw_core;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/FmmMesh/gw_geodesic;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/FmmMesh/gw_maths"
89 )
90
91 # Import target "GeodesicMeasurement::GeodesicMeasurementFilters" for configuration "Release"
92 set_property(TARGET GeodesicMeasurement::GeodesicMeasurementFilters APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
93 set_target_properties(GeodesicMeasurement::GeodesicMeasurementFilters PROPERTIES
94  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonCore;VTK::CommonDataModel;VTK::FiltersCore;VTK::FiltersModeling"
95  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/GeodesicMeasurement/libvtkGeodesicMeasurementFilters.so"
96  IMPORTED_SONAME_RELEASE "libvtkGeodesicMeasurementFilters.so"
97  )
98
99 # Import target "GeodesicMeasurement::FmmMesh" for configuration "Release"
100 set_property(TARGET GeodesicMeasurement::FmmMesh APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
101 set_target_properties(GeodesicMeasurement::FmmMesh PROPERTIES
102  IMPORTED_LINK_INTERFACE_LANGUAGES_RELEASE "CXX"
103  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/GeodesicMeasurement/libFmmMesh.a"
104  )
105
106 # Make sure the targets which have been exported in some other
107 # export set exist.
108 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
109 foreach(_target "VTK::CommonExecutionModel" )
110  if(NOT TARGET "${_target}" )
111  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
112  endif()
113 endforeach()
114
115 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
116  if(CMAKE_FIND_PACKAGE_NAME)
117  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
118  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
119  else()
120  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
121  endif()
122 endif()
123 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
124
125 # Commands beyond this point should not need to know the version.
126 set(CMAKE_IMPORT_FILE_VERSION)
127 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:20
