paraview-config-version.cmake
1 # This is a basic version file for the Config-mode of find_package().
2 # It is used by write_basic_package_version_file() as input file for configure_file()
3 # to create a version-file which can be installed along a config.cmake file.
4 #
5 # The created file sets PACKAGE_VERSION_EXACT if the current version string and
6 # the requested version string are exactly the same and it sets
7 # PACKAGE_VERSION_COMPATIBLE if the current version is >= requested version.
8 # The variable CVF_VERSION must be set before calling configure_file().
9
10 set(PACKAGE_VERSION "6.1.1-773-g9418a1e6ce")
11
12 if (PACKAGE_FIND_VERSION_RANGE)
13  # Package version must be in the requested version range
14  if ((PACKAGE_FIND_VERSION_RANGE_MIN STREQUAL "INCLUDE" AND PACKAGE_VERSION VERSION_LESS PACKAGE_FIND_VERSION_MIN)
15  OR ((PACKAGE_FIND_VERSION_RANGE_MAX STREQUAL "INCLUDE" AND PACKAGE_VERSION VERSION_GREATER PACKAGE_FIND_VERSION_MAX)
16  OR (PACKAGE_FIND_VERSION_RANGE_MAX STREQUAL "EXCLUDE" AND PACKAGE_VERSION VERSION_GREATER_EQUAL PACKAGE_FIND_VERSION_MAX)))
17  set(PACKAGE_VERSION_COMPATIBLE FALSE)
18  else()
19  set(PACKAGE_VERSION_COMPATIBLE TRUE)
20  endif()
21 else()
22  if(PACKAGE_VERSION VERSION_LESS PACKAGE_FIND_VERSION)
23  set(PACKAGE_VERSION_COMPATIBLE FALSE)
24  else()
25  set(PACKAGE_VERSION_COMPATIBLE TRUE)
26  if(PACKAGE_FIND_VERSION STREQUAL PACKAGE_VERSION)
27  set(PACKAGE_VERSION_EXACT TRUE)
28  endif()
29  endif()
30 endif()
31
32
33 # if the installed or the using project don't have CMAKE_SIZEOF_VOID_P set, ignore it:
34 if("${CMAKE_SIZEOF_VOID_P}" STREQUAL "" OR "8" STREQUAL "")
35  return()
36 endif()
37
38 # check that the installed version has the same 32/64bit-ness as the one which is currently searching:
39 if(NOT CMAKE_SIZEOF_VOID_P STREQUAL "8")
40  math(EXPR installedBits "8 * 8")
41  set(PACKAGE_VERSION "${PACKAGE_VERSION} (${installedBits}bit)")
42  set(PACKAGE_VERSION_UNSUITABLE TRUE)
#define PACKAGE_VERSION
Definition: expat_config.h:85
