3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
6 if(CMAKE_VERSION VERSION_LESS "3.0.0")
7 message(FATAL_ERROR "CMake >= 3.0.0 required")
10 cmake_policy(
VERSION 3.0.0...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS ParaView::PyvtkPVIncubatorCorePython ParaView::pvincubatorpythonmodules)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Create imported target ParaView::PyvtkPVIncubatorCorePython 50 add_library(ParaView::PyvtkPVIncubatorCorePython MODULE IMPORTED) 52 # Create imported target ParaView::pvincubatorpythonmodules 53 add_library(ParaView::pvincubatorpythonmodules INTERFACE IMPORTED) 55 set_target_properties(ParaView::pvincubatorpythonmodules PROPERTIES 56 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/include/paraview-6.1/pvincubatorpythonmodules
" 57 INTERFACE_LINK_LIBRARIES "VTK::vtkpythonmodules
" 60 # Import target "ParaView::PyvtkPVIncubatorCorePython
" for configuration "Release
" 61 set_property(TARGET ParaView::PyvtkPVIncubatorCorePython APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 62 set_target_properties(ParaView::PyvtkPVIncubatorCorePython PROPERTIES 63 IMPORTED_COMMON_LANGUAGE_RUNTIME_RELEASE "" 64 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/paraview/incubator/vtkPVIncubatorCore.so
" 65 IMPORTED_NO_SONAME_RELEASE "TRUE
" 68 # Make sure the targets which have been exported in some other 70 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 71 foreach(_target "VTK::vtkpythonmodules
" ) 72 if(NOT TARGET "${_target}
" ) 73 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 77 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 78 if(CMAKE_FIND_PACKAGE_NAME) 79 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 80 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 82 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 85 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 87 # Commands beyond this point should not need to know the version. 88 set(CMAKE_IMPORT_FILE_VERSION)
