3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
10 cmake_policy(
VERSION 2.8.3...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS ParaView::pvserver ParaView::pvdataserver ParaView::pvrenderserver ParaView::pvbatch ParaView::pvpython)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Create imported target ParaView::pvserver 50 add_executable(ParaView::pvserver IMPORTED) 52 # Create imported target ParaView::pvdataserver 53 add_executable(ParaView::pvdataserver IMPORTED) 55 # Create imported target ParaView::pvrenderserver 56 add_executable(ParaView::pvrenderserver IMPORTED) 58 # Create imported target ParaView::pvbatch 59 add_executable(ParaView::pvbatch IMPORTED) 61 # Create imported target ParaView::pvpython 62 add_executable(ParaView::pvpython IMPORTED) 64 # Import target "ParaView::pvserver
" for configuration "Release
" 65 set_property(TARGET ParaView::pvserver APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 66 set_target_properties(ParaView::pvserver PROPERTIES 67 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/bin/pvserver
" 70 # Import target "ParaView::pvdataserver
" 71 set_property(TARGET ParaView::pvdataserver APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 72 set_target_properties(ParaView::pvdataserver PROPERTIES 73 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/bin/pvdataserver
" 76 # Import target "ParaView::pvrenderserver
" 77 set_property(TARGET ParaView::pvrenderserver APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 78 set_target_properties(ParaView::pvrenderserver PROPERTIES 79 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/bin/pvrenderserver
" 82 # Import target "ParaView::pvbatch
" 83 set_property(TARGET ParaView::pvbatch APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 84 set_target_properties(ParaView::pvbatch PROPERTIES 85 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch
" 88 # Import target "ParaView::pvpython
" 89 set_property(TARGET ParaView::pvpython APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 90 set_target_properties(ParaView::pvpython PROPERTIES 91 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/bin/pvpython
" 94 # This file does not depend on other imported targets which have 95 # been exported from the same project but in a separate export set. 97 # Commands beyond this point should not need to know the version. 98 set(CMAKE_IMPORT_FILE_VERSION)
