NonOrthogonalSource-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "2.8.3")
7  message(FATAL_ERROR "CMake >= 2.8.3 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 2.8.3...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS NonOrthogonalSource::vtkNonOrthogonalSources)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Create imported target NonOrthogonalSource::vtkNonOrthogonalSources
50 add_library(NonOrthogonalSource::vtkNonOrthogonalSources SHARED IMPORTED)
51
52 set_target_properties(NonOrthogonalSource::vtkNonOrthogonalSources PROPERTIES
53  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources;/builds/gitlab-kitware-sciviz-ci/build/Plugins/NonOrthogonalSource/Sources;/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources;/builds/gitlab-kitware-sciviz-ci/build/Plugins/NonOrthogonalSource/Sources;/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources;/builds/gitlab-kitware-sciviz-ci/build/Plugins/NonOrthogonalSource/Sources"
54  INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel;VTK::PythonUsed"
55 )
56
57 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
58  target_sources(NonOrthogonalSource::vtkNonOrthogonalSources
59  INTERFACE
60  FILE_SET "vtk_module_templates"
61  TYPE "HEADERS"
62  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources"
63  FILES
64  INTERFACE
65  FILE_SET "vtk_module_headers"
66  TYPE "HEADERS"
67  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources"
68  FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources/vtkShearedWaveletSource.h"
69  INTERFACE
70  FILE_SET "vtk_module_nowrap_headers"
71  TYPE "HEADERS"
72  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources"
73  FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/NonOrthogonalSource/Sources/vtkNonOrthogonalSourcesModule.h"
74  )
75 else()
76  set_property(TARGET NonOrthogonalSource::vtkNonOrthogonalSources
77  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
78  "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources"
79  "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources"
80  "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources"
81  )
82 endif()
83
84 # Import target "NonOrthogonalSource::vtkNonOrthogonalSources" for configuration "Release"
85 set_property(TARGET NonOrthogonalSource::vtkNonOrthogonalSources APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
86 set_target_properties(NonOrthogonalSource::vtkNonOrthogonalSources PROPERTIES
87  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::VTKExtensionsMisc;VTK::CommonCore;VTK::CommonDataModel;VTK::CommonMath;VTK::CommonTransforms;VTK::FiltersGeneral;VTK::ImagingCore"
88  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/NonOrthogonalSource/libvtkNonOrthogonalSources.so"
89  IMPORTED_SONAME_RELEASE "libvtkNonOrthogonalSources.so"
90  )
91
92 # Make sure the targets which have been exported in some other
93 # export set exist.
94 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
95 foreach(_target "VTK::CommonExecutionModel" "VTK::PythonUsed" )
96  if(NOT TARGET "${_target}" )
97  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
98  endif()
99 endforeach()
100
101 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
102  if(CMAKE_FIND_PACKAGE_NAME)
103  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
104  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
105  else()
106  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
107  endif()
108 endif()
109 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
110
111 # Commands beyond this point should not need to know the version.
112 set(CMAKE_IMPORT_FILE_VERSION)
113 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
