3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
10 cmake_policy(
VERSION 2.8.3...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS LegacyGhostCellsGeneratorFilters LegacyGhostCellsGeneratorParallel)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Create imported target LegacyGhostCellsGeneratorFilters 50 add_library(LegacyGhostCellsGeneratorFilters SHARED IMPORTED) 52 set_target_properties(LegacyGhostCellsGeneratorFilters PROPERTIES 53 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Filters
" 54 INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel
") 58 target_sources(LegacyGhostCellsGeneratorFilters 60 FILE_SET "vtk_module_templates
" 62 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters
" 67 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters
" 68 FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters/vtkUnstructuredGridGhostCellsGenerator.h
" 72 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters
" 73 FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Filters/LegacyGhostCellsGeneratorFiltersModule.h
" 76 set_property(TARGET LegacyGhostCellsGeneratorFilters 77 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 78 "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters
" 79 "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters
" 80 "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters
" 84 # Create imported target LegacyGhostCellsGeneratorParallel 85 add_library(LegacyGhostCellsGeneratorParallel SHARED IMPORTED) 87 set_target_properties(LegacyGhostCellsGeneratorParallel PROPERTIES 88 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel;/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Parallel;/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel;/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Parallel;/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel;/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Parallel
" 89 INTERFACE_LINK_LIBRARIES "LegacyGhostCellsGeneratorFilters;VTK::CommonExecutionModel;VTK::CommonSystem;VTK::FiltersCore;VTK::FiltersGeneral;VTK::FiltersGeometry;VTK::ParallelMPI
" 92 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 93 target_sources(LegacyGhostCellsGeneratorParallel 95 FILE_SET "vtk_module_templates
" 97 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel
" 100 FILE_SET "vtk_module_headers
" 102 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel
" 105 FILE_SET "vtk_module_nowrap_headers
" 107 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel
" 108 FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Parallel/LegacyGhostCellsGeneratorParallelModule.h
" 111 set_property(TARGET LegacyGhostCellsGeneratorParallel 112 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 113 "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel
" 114 "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel
" 115 "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel
" 119 # Import target "LegacyGhostCellsGeneratorFilters
" for configuration "Release
" 120 set_property(TARGET LegacyGhostCellsGeneratorFilters APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 121 set_target_properties(LegacyGhostCellsGeneratorFilters PROPERTIES 122 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonMisc;VTK::ParallelCore
" 123 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorFilters.so
" 124 IMPORTED_SONAME_RELEASE "libLegacyGhostCellsGeneratorFilters.so
" 127 # Import target "LegacyGhostCellsGeneratorParallel
" 128 set_property(TARGET LegacyGhostCellsGeneratorParallel APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 129 set_target_properties(LegacyGhostCellsGeneratorParallel PROPERTIES 130 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonMisc;VTK::ParallelCore
" 131 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorParallel.so
" 132 IMPORTED_SONAME_RELEASE "libLegacyGhostCellsGeneratorParallel.so
" 135 # Make sure the targets which have been exported in some other 137 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 138 foreach(_target "VTK::CommonExecutionModel
" "VTK::CommonSystem
" "VTK::FiltersCore
" "VTK::FiltersGeneral
" "VTK::FiltersGeometry
" "VTK::ParallelMPI
" ) 139 if(NOT TARGET "${_target}
" ) 140 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 144 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 145 if(CMAKE_FIND_PACKAGE_NAME) 146 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 147 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 149 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 152 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 154 # Commands beyond this point should not need to know the version. 155 set(CMAKE_IMPORT_FILE_VERSION)
