DigitalSignalProcessing-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "2.8.3")
7  message(FATAL_ERROR "CMake >= 2.8.3 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 2.8.3...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS DigitalSignalProcessing::DSPDataModel DigitalSignalProcessing::DSPFiltersPlugin)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Create imported target DigitalSignalProcessing::DSPDataModel
50 add_library(DigitalSignalProcessing::DSPDataModel STATIC IMPORTED)
51
52 set_target_properties(DigitalSignalProcessing::DSPDataModel PROPERTIES
53  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel;/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel;/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel;/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel;/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel;/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel"
54  INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::CommonExecutionModel;\$<LINK_ONLY:VTK::CommonDataModel>"
55 )
56
57 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
58  target_sources(DigitalSignalProcessing::DSPDataModel
59  INTERFACE
60  FILE_SET "vtk_module_templates"
61  TYPE "HEADERS"
62  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel"
63  FILES
64  INTERFACE
65  FILE_SET "vtk_module_headers"
66  TYPE "HEADERS"
67  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel"
68  FILES
69  INTERFACE
70  FILE_SET "vtk_module_nowrap_headers"
71  TYPE "HEADERS"
72  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel"
73  FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel/vtkArrayDispatchDSPArrayList.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel/vtkMultiDimensionalArray.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel/vtkMultiDimensionalImplicitBackend.h" "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel/vtkDSPDataModelModule.h"
74  )
75 else()
76  set_property(TARGET DigitalSignalProcessing::DSPDataModel
77  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
78  "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel"
79  "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel"
80  "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel"
81  )
82 endif()
83
84 # Create imported target DigitalSignalProcessing::DSPFiltersPlugin
85 add_library(DigitalSignalProcessing::DSPFiltersPlugin STATIC IMPORTED)
86
87 set_target_properties(DigitalSignalProcessing::DSPFiltersPlugin PROPERTIES
88  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/Filters"
89  INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonExecutionModel;VTK::FiltersGeneral;\$<LINK_ONLY:DigitalSignalProcessing::DSPDataModel>;\$<LINK_ONLY:VTK::FiltersCore>;\$<LINK_ONLY:VTK::FiltersExtraction>;\$<LINK_ONLY:VTK::ParallelCore>"
90 )
91
92 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
93  target_sources(DigitalSignalProcessing::DSPFiltersPlugin
94  INTERFACE
95  FILE_SET "vtk_module_templates"
96  TYPE "HEADERS"
97  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters"
98  FILES
99  INTERFACE
100  FILE_SET "vtk_module_headers"
101  TYPE "HEADERS"
102  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters"
103  FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkAccousticUtilities.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkBandFiltering.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkDSPTableFFT.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkMeanPowerSpectralDensity.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkMergeReduceTables.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkMultiDimensionBrowser.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkProjectSpectrumMagnitude.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkSoundQuantitiesCalculator.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkSpectrogramFilter.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkTemporalMultiplexing.h"
104  INTERFACE
105  FILE_SET "vtk_module_nowrap_headers"
106  TYPE "HEADERS"
107  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters"
108  FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/Filters/vtkDSPFiltersPluginModule.h"
109  )
110 else()
111  set_property(TARGET DigitalSignalProcessing::DSPFiltersPlugin
112  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
113  "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters"
114  "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters"
115  "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters"
116  )
117 endif()
118
119 # Import target "DigitalSignalProcessing::DSPDataModel" for configuration "Release"
120 set_property(TARGET DigitalSignalProcessing::DSPDataModel APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
121 set_target_properties(DigitalSignalProcessing::DSPDataModel PROPERTIES
122  IMPORTED_LINK_INTERFACE_LANGUAGES_RELEASE "CXX"
123  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/DigitalSignalProcessing/libvtkDSPDataModel.a"
124  )
125
126 # Import target "DigitalSignalProcessing::DSPFiltersPlugin" for configuration "Release"
127 set_property(TARGET DigitalSignalProcessing::DSPFiltersPlugin APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
128 set_target_properties(DigitalSignalProcessing::DSPFiltersPlugin PROPERTIES
129  IMPORTED_LINK_INTERFACE_LANGUAGES_RELEASE "CXX"
130  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/DigitalSignalProcessing/libvtkDSPFiltersPlugin.a"
131  )
132
133 # Make sure the targets which have been exported in some other
134 # export set exist.
135 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
136 foreach(_target "VTK::CommonCore" "VTK::CommonExecutionModel" "VTK::CommonDataModel" "VTK::FiltersGeneral" "VTK::FiltersCore" "VTK::FiltersExtraction" "VTK::ParallelCore" )
137  if(NOT TARGET "${_target}" )
138  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
139  endif()
140 endforeach()
141
142 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
143  if(CMAKE_FIND_PACKAGE_NAME)
144  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
145  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
146  else()
147  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
148  endif()
149 endif()
150 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
151
152 # Commands beyond this point should not need to know the version.
153 set(CMAKE_IMPORT_FILE_VERSION)
154 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
