1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Python 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
"python" OR NOT CMAKE_INSTALL_COMPONENT)
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules" TYPE FILE FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/generate_pyi.py")
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
50 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/
vtk.py
") 53 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 54 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/__init__.py
") 57 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 58 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/all.py
") 61 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 62 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/gtk
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/gtk/GtkGLExtVTKRenderWindow.py
") 65 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 66 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/gtk
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/gtk/GtkGLExtVTKRenderWindowInteractor.py
") 69 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 70 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/gtk
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/gtk/GtkVTKRenderWindow.py
") 73 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 74 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/gtk
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/gtk/GtkVTKRenderWindowInteractor.py
") 77 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 78 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/gtk
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/gtk/__init__.py
") 81 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 82 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/__init__.py
") 85 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 86 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/_vtk_array_mixin.py
") 89 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/array_overrides.py
") 93 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 94 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/vtk_affine_array.py
") 97 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 98 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/vtk_aos_array.py
") 101 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 102 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/vtk_constant_array.py
") 105 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 106 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/vtk_none_array.py
") 109 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 110 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/vtk_partitioned_array.py
") 113 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 114 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/vtk_soa_array.py
") 117 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 118 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/vtk_implicit_array.py
") 121 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 122 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/vtk_strided_array.py
") 125 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 126 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/vtk_indexed_array.py
") 129 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 130 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/vtk_composite_array.py
") 133 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 134 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/vtk_structured_point_array.py
") 137 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 138 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/utils.py
") 141 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 142 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/algorithms.py
") 145 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 146 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/dataset_adapter.py
") 149 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 150 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/internal_algorithms.py
") 153 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 154 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/numpy_interface
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/numpy_interface/numpy_algorithms.py
") 157 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 158 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/qt
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/qt/QVTKRenderWindowInteractor.py
") 161 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 162 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/qt
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/qt/__init__.py
") 165 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 166 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/test
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/test/BlackBox.py
") 169 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 170 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/test
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/test/ErrorObserver.py
") 173 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 174 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/test
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/test/Testing.py
") 177 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 178 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/test
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/test/rtImageTest.py
") 181 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 182 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/test
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/test/__init__.py
") 185 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 186 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/tk
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/tk/__init__.py
") 189 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 190 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/tk
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/tk/vtkLoadPythonTkWidgets.py
") 193 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 194 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/tk
vtkTkImageViewerWidget.py
") 197 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 198 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/tk
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/tk/vtkTkPhotoImage.py
") 201 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 202 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/tk
vtkTkRenderWidget.py
") 205 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 206 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/tk
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/tk/vtkTkRenderWindowInteractor.py
") 209 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 210 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/__init__.py
") 213 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 214 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/colors.py
") 217 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 218 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/data_array_selection.py
") 221 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 222 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/data_model.py
") 225 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 226 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/execution_model.py
") 229 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 230 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/functions.py
") 233 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 234 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/graph.py
") 237 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 238 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/implicit_functions.py
") 241 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 242 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/information.py
") 245 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 246 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/keys.py
") 249 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 250 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/matrix.py
") 253 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 254 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/misc.py
") 257 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 258 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/molecule.py
") 261 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 262 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/selection.py
") 265 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 266 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/string_array.py
") 269 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 270 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/variant_array.py
") 273 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 274 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/widgets.py
") 277 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 278 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/numpy_support.py
") 281 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 282 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/views_scivis.py
") 285 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 286 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/xarray_support.py
") 289 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 290 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/pickle_support.py
") 293 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 294 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
vtkAlgorithm.py
") 297 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 298 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/vtkConstants.py
") 301 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 302 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/vtkImageExportToArray.py
") 305 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 306 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/vtkImageImportFromArray.py
") 309 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 310 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/util/vtkMethodParser.py
") 313 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 314 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/util
vtkVariant.py
") 317 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 318 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/wx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/wx/__init__.py
") 321 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 322 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/wx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/wx/wxVTKRenderWindow.py
") 325 if(CMAKE_INSTALL_COMPONENT STREQUAL "python
" OR NOT CMAKE_INSTALL_COMPONENT) 326 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/vtkmodules/wx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/vtkmodules/wx/wxVTKRenderWindowInteractor.py
