1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Web/Python
40 # Set path to fallback-tool for dependency-resolution.
42  set(CMAKE_OBJDUMP "/usr/sbin/objdump")
45 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.14/site-packages/vtkmodules/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Web/Python/vtkmodules/web/__init__.py")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.14/site-packages/vtkmodules/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Web/Python/vtkmodules/web/camera.py")
51 endif()
52
53 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.14/site-packages/vtkmodules/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Web/Python/vtkmodules/web/dataset_builder.py")
55 endif()
56
57 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.14/site-packages/vtkmodules/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Web/Python/vtkmodules/web/errors.py")
59 endif()
60
61 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.14/site-packages/vtkmodules/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Web/Python/vtkmodules/web/protocols.py")
63 endif()
64
65 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.14/site-packages/vtkmodules/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Web/Python/vtkmodules/web/query_data_model.py")
67 endif()
68
69 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.14/site-packages/vtkmodules/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Web/Python/vtkmodules/web/render_window_serializer.py")
71 endif()
72
73 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.14/site-packages/vtkmodules/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Web/Python/vtkmodules/web/testing.py")
75 endif()
76
77 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.14/site-packages/vtkmodules/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Web/Python/vtkmodules/web/vtkjs_helper.py")
79 endif()
80
81 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.14/site-packages/vtkmodules/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Web/Python/vtkmodules/web/venv.py")
83 endif()
84
85 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.14/site-packages/vtkmodules/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Web/Python/vtkmodules/web/wslink.py")
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.14/site-packages/vtkmodules/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Web/Python/vtkmodules/web/utils.py")
91 endif()
92
93 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
94  "${CMAKE_INSTALL_MANIFEST_FILES}")
95 if(CMAKE_INSTALL_LOCAL_ONLY)
96  file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/VTK/Web/Python/install_local_manifest.txt"
97  "${CMAKE_INSTALL_MANIFEST_CONTENT}")
98 endif()
