1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Utilities/Python 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
40 # Set path to fallback-tool for dependency-resolution. 41 if(NOT DEFINED CMAKE_OBJDUMP)
42 set(CMAKE_OBJDUMP
"/usr/sbin/objdump")
48 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
49 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2
" TYPE FILE FILES 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/Python/vtkPython.h
" 51 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/Python/vtkPythonConfigure.h
" 55 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 58 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 59 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/Python/vtkPython.spdx
") 62 string(REPLACE ";
" "\n
" CMAKE_INSTALL_MANIFEST_CONTENT 63 "${CMAKE_INSTALL_MANIFEST_FILES}
") 64 if(CMAKE_INSTALL_LOCAL_ONLY) 65 file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/Python/install_local_manifest.txt
" 66 "${CMAKE_INSTALL_MANIFEST_CONTENT}
