1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Utilities/KWIML/vtkkwiml 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
40 # Set path to fallback-tool for dependency-resolution. 41 if(NOT DEFINED CMAKE_OBJDUMP)
42 set(CMAKE_OBJDUMP
"/usr/sbin/objdump")
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/vtkkwiml" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/KWIML/vtkkwiml/include/kwiml/abi.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/KWIML/vtkkwiml/include/kwiml/int.h" 52 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
53 # Include the install script for the subdirectory. 54 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWIML/vtkkwiml/test/cmake_install.cmake")
57 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
58 "${CMAKE_INSTALL_MANIFEST_FILES}
") 59 if(CMAKE_INSTALL_LOCAL_ONLY) 60 file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/KWIML/vtkkwiml/install_local_manifest.txt
" 61 "${CMAKE_INSTALL_MANIFEST_CONTENT}
