1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Utilities/Catalyst 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
40 # Set path to fallback-tool for dependency-resolution. 41 if(NOT DEFINED CMAKE_OBJDUMP)
42 set(CMAKE_OBJDUMP
"/usr/sbin/objdump")
45 string(REPLACE
";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
46 "${CMAKE_INSTALL_MANIFEST_FILES}")
47 if(CMAKE_INSTALL_LOCAL_ONLY)
48 file(WRITE
"/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/Catalyst/install_local_manifest.txt" 49 "${CMAKE_INSTALL_MANIFEST_CONTENT}")
