1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vpic
40 # Set path to fallback-tool for dependency-resolution.
42  set(CMAKE_OBJDUMP "/usr/sbin/objdump")
47  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vpic/vtkvpic/cmake_install.cmake")
48 endif()
49
50 if(CMAKE_INSTALL_COMPONENT STREQUAL "license" OR NOT CMAKE_INSTALL_COMPONENT)
51  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkvpic" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vpic/vtkvpic/LICENSE")
52 endif()
53
54 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
55  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vpic/vtkvpic.spdx")
56 endif()
57
58 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
59  "${CMAKE_INSTALL_MANIFEST_FILES}")
60 if(CMAKE_INSTALL_LOCAL_ONLY)
61  file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vpic/install_local_manifest.txt"
62  "${CMAKE_INSTALL_MANIFEST_CONTENT}")
63 endif()
