1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/scn
47  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/scn/vtkscn/cmake_install.cmake")
48 endif()
49
50 if(CMAKE_INSTALL_COMPONENT STREQUAL "license" OR NOT CMAKE_INSTALL_COMPONENT)
51  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkscn" TYPE FILE FILES
52  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/scn/vtkscn/LICENSE"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/scn/vtkscn/LICENSE.nanorange"
54  )
55 endif()
56
57 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/scn/vtkscn.spdx")
59 endif()
60
61 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/scn/vtk_scn.h")
63 endif()
64
