1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma
40 # Set path to fallback-tool for dependency-resolution.
42  set(CMAKE_OBJDUMP "/usr/sbin/objdump")
45 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
46  foreach(file
47  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv6.2.so.6.2"
48  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv6.2.so.1"
49  )
50  if(EXISTS "${file}" AND
51  NOT IS_SYMLINK "${file}")
52  file(RPATH_CHECK
53  FILE "${file}"
54  RPATH "\$ORIGIN")
55  endif()
56  endforeach()
57  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
58  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtklzma-pv6.2.so.6.2"
59  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtklzma-pv6.2.so.1"
60  )
61  foreach(file
62  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv6.2.so.6.2"
63  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv6.2.so.1"
64  )
65  if(EXISTS "${file}" AND
66  NOT IS_SYMLINK "${file}")
67  file(RPATH_CHANGE
68  FILE "${file}"
69  OLD_RPATH ":::::::"
70  NEW_RPATH "\$ORIGIN")
71  if(CMAKE_INSTALL_DO_STRIP)
72  execute_process(COMMAND "/usr/sbin/strip" "${file}")
73  endif()
74  endif()
75  endforeach()
76 endif()
77
78 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
79  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtklzma-pv6.2.so")
80 endif()
81
83 endif()
84
85 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/vtklzma/src/liblzma/api" TYPE FILE FILES
87  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma.h"
88  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/vtk_lzma_mangle.h"
89  )
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/vtklzma/src/liblzma/api/lzma" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/base.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/bcj.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/block.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/check.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/container.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/delta.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/filter.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/hardware.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/index.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/index_hash.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/lzma12.h"
102  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/stream_flags.h"
103  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/version.h"
104  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/vli.h"
105  )
106 endif()
107
108 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
109 endif()
110
111 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
112  "${CMAKE_INSTALL_MANIFEST_FILES}")
113 if(CMAKE_INSTALL_LOCAL_ONLY)
114  file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/lzma/vtklzma/install_local_manifest.txt"
115  "${CMAKE_INSTALL_MANIFEST_CONTENT}")
116 endif()
version
index
