1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/jpeg/vtkjpeg
40 # Set path to fallback-tool for dependency-resolution.
42  set(CMAKE_OBJDUMP "/usr/sbin/objdump")
45 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
46  foreach(file
47  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv6.2.so.6.2"
48  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv6.2.so.1"
49  )
50  if(EXISTS "${file}" AND
51  NOT IS_SYMLINK "${file}")
52  file(RPATH_CHECK
53  FILE "${file}"
54  RPATH "\$ORIGIN")
55  endif()
56  endforeach()
57  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
58  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkjpeg-pv6.2.so.6.2"
59  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkjpeg-pv6.2.so.1"
60  )
61  foreach(file
62  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv6.2.so.6.2"
63  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv6.2.so.1"
64  )
65  if(EXISTS "${file}" AND
66  NOT IS_SYMLINK "${file}")
67  file(RPATH_CHANGE
68  FILE "${file}"
69  OLD_RPATH ":::::::"
70  NEW_RPATH "\$ORIGIN")
71  if(CMAKE_INSTALL_DO_STRIP)
72  execute_process(COMMAND "/usr/sbin/strip" "${file}")
73  endif()
74  endif()
75  endforeach()
76 endif()
77
78 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
79  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkjpeg-pv6.2.so")
80 endif()
81
83 endif()
84
85 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/vtkjpeg/src" TYPE FILE FILES
87  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/jpeg/vtkjpeg/src/jerror.h"
88  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/jpeg/vtkjpeg/src/jmorecfg.h"
89  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/jpeg/vtkjpeg/src/jpeglib.h"
90  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/jpeg/vtkjpeg/src/vtk_jpeg_mangle.h"
91  "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/jpeg/vtkjpeg/src/jconfig.h"
92  )
93 endif()
94
95 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
96 endif()
97
98 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
99  "${CMAKE_INSTALL_MANIFEST_FILES}")
100 if(CMAKE_INSTALL_LOCAL_ONLY)
101  file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/jpeg/vtkjpeg/install_local_manifest.txt"
102  "${CMAKE_INSTALL_MANIFEST_CONTENT}")
103 endif()
