1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2
40 # Set path to fallback-tool for dependency-resolution.
42  set(CMAKE_OBJDUMP "/usr/sbin/objdump")
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkRenderingVolumeOpenGL2-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRenderingVolumeOpenGL2-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv6.2.so.6.2"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv6.2.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingVolumeOpenGL2-pv6.2.so.6.2"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingVolumeOpenGL2-pv6.2.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv6.2.so.6.2"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolumeOpenGL2-pv6.2.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:"
74  NEW_RPATH "\$ORIGIN")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/sbin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingVolumeOpenGL2-pv6.2.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeLookupTables.txx")
88 endif()
89
90 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
91  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES
92  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkMultiBlockUnstructuredGridVolumeMapper.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkMultiBlockVolumeMapper.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLGPUVolumeRayCastMapper.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLProjectedTetrahedraMapper.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLRayCastImageDisplayHelper.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLSurfaceProbeVolumeMapper.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkSmartVolumeMapper.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkVolumeTexture.h"
100  )
101 endif()
102
103 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
104  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES
105  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeGradientOpacityTable.h"
106  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeLookupTable.h"
107  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeMaskGradientOpacityTransferFunction2D.h"
108  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeMaskTransferFunction2D.h"
109  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeOpacityTable.h"
110  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeRGBTable.h"
111  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeTransferFunction2D.h"
112  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkVolumeInputHelper.h"
113  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/VolumeOpenGL2/vtkOpenGLVolumeLookupTables.h"
114  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/VolumeOpenGL2/vtkRenderingVolumeOpenGL2Module.h"
115  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/VolumeOpenGL2/vtkRenderingVolumeOpenGL2SerDes.h"
116  )
117 endif()
118
119 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
120  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/VolumeOpenGL2/vtkRenderingVolumeOpenGL2.spdx")
121 endif()
122
123 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
124  "${CMAKE_INSTALL_MANIFEST_FILES}")
125 if(CMAKE_INSTALL_LOCAL_ONLY)
126  file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/VolumeOpenGL2/install_local_manifest.txt"
127  "${CMAKE_INSTALL_MANIFEST_CONTENT}")
128 endif()
