1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/UI 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
40 # Set path to fallback-tool for dependency-resolution. 41 if(NOT DEFINED CMAKE_OBJDUMP)
42 set(CMAKE_OBJDUMP
"/usr/sbin/objdump")
46 file(INSTALL DESTINATION
"vtkRenderingUI-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRenderingUI-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingUI-pv6.2.so.6.2
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingUI-pv6.2.so.1
" 54 if(EXISTS "${file}
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingUI-pv6.2.so.6.2
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingUI-pv6.2.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingUI-pv6.2.so.6.2
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingUI-pv6.2.so.1
" 69 if(EXISTS "${file}
") 75 if(CMAKE_INSTALL_DO_STRIP) 76 execute_process(COMMAND "/usr/sbin/strip
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingUI-pv6.2.so
" TYPE FILE FILES 93 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/UI/vtkXlibHardwareWindow.h
" 97 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 98 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2
" TYPE FILE FILES 99 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/UI/vtkRenderingUIModule.h
" 100 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/UI/vtkRenderingUISerDes.h
" 104 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 105 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/UI/vtkRenderingUI.spdx
") 108 string(REPLACE ";
" "\n
" CMAKE_INSTALL_MANIFEST_CONTENT 109 "${CMAKE_INSTALL_MANIFEST_FILES}
") 110 if(CMAKE_INSTALL_LOCAL_ONLY) 111 file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/UI/install_local_manifest.txt
" 112 "${CMAKE_INSTALL_MANIFEST_CONTENT}
