1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel
40 # Set path to fallback-tool for dependency-resolution.
42  set(CMAKE_OBJDUMP "/usr/sbin/objdump")
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkRenderingParallel-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRenderingParallel-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv6.2.so.6.2"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv6.2.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingParallel-pv6.2.so.6.2"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingParallel-pv6.2.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv6.2.so.6.2"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingParallel-pv6.2.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
74  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/sbin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingParallel-pv6.2.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Parallel/vtkCompositeZPassFS.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkClientServerCompositePass.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkClientServerSynchronizedRenderers.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkCompositedSynchronizedRenderers.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkCompositer.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkCompositeRenderManager.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkCompositeRGBAPass.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkCompositeZPass.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkCompressCompositer.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkImageRenderManager.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkIndependentViewerCollection.h"
102  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkParallelRenderManager.h"
103  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkPHardwareSelector.h"
104  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkSynchronizableActors.h"
105  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkSynchronizableAvatars.h"
106  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkSynchronizedRenderers.h"
107  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkSynchronizedRenderWindows.h"
108  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/vtkTreeCompositer.h"
109  )
110 endif()
111
112 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
113  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Parallel/vtkRenderingParallelModule.h")
114 endif()
115
116 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses" OR NOT CMAKE_INSTALL_COMPONENT)
117  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkRenderingParallel" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Parallel/LICENSE")
118 endif()
119
120 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
121  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Parallel/vtkRenderingParallel.spdx")
122 endif()
123
124 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
125  "${CMAKE_INSTALL_MANIFEST_FILES}")
126 if(CMAKE_INSTALL_LOCAL_ONLY)
127  file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Parallel/install_local_manifest.txt"
128  "${CMAKE_INSTALL_MANIFEST_CONTENT}")
129 endif()
VTK_ABI_NAMESPACE_BEGIN VTKRENDERINGPARALLEL_EXPORT const char * vtkCompositeZPassFS
