1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkRenderingAnnotation-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRenderingAnnotation-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv6.1.so.6.1"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv6.1.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingAnnotation-pv6.1.so.6.1"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingAnnotation-pv6.1.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv6.1.so.6.1"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingAnnotation-pv6.1.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:"
74  NEW_RPATH "\$ORIGIN")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/bin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingAnnotation-pv6.1.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.1" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkAnnotatedCubeActor.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkArcPlotter.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkAxesActor.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkAxisActor.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkAxisActor2D.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkAxisFollower.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkBarChartActor.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkCaptionActor2D.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkConvexHull2D.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkCornerAnnotation.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkCubeAxesActor.h"
102  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkCubeAxesActor2D.h"
103  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkGraphAnnotationLayersFilter.h"
104  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkLeaderActor2D.h"
105  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkLegendBoxActor.h"
106  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkLegendScaleActor.h"
107  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkParallelCoordinatesActor.h"
108  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkPieChartActor.h"
109  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkPolarAxesActor.h"
110  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkPolarAxesActor2D.h"
111  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkProp3DAxisFollower.h"
112  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkRadialGridActor2D.h"
113  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkScalarBarActor.h"
114  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkSpiderPlotActor.h"
115  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkXYPlotActor.h"
116  )
117 endif()
118
119 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
120  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.1" TYPE FILE FILES
121  "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Annotation/vtkScalarBarActorInternal.h"
122  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Annotation/vtkRenderingAnnotationModule.h"
123  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Annotation/vtkRenderingAnnotationSerDes.h"
124  )
125 endif()
126
127 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
128  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Annotation/vtkRenderingAnnotation.spdx")
129 endif()
130
