1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/TRUCHAS
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOTRUCHAS-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOTRUCHAS-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOTRUCHAS-pv6.0.so.6.0"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOTRUCHAS-pv6.0.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOTRUCHAS-pv6.0.so.6.0"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOTRUCHAS-pv6.0.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOTRUCHAS-pv6.0.so.6.0"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOTRUCHAS-pv6.0.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:"
74  NEW_RPATH "\$ORIGIN")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/bin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOTRUCHAS-pv6.0.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/IO/TRUCHAS/vtkTRUCHASReader.h")
91 endif()
92
93 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/TRUCHAS/vtkIOTRUCHASModule.h")
95 endif()
96
97 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
98  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/TRUCHAS/vtkIOTRUCHAS.spdx")
99 endif()
100
