1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/Image
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOImage-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOImage-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOImage-pv6.0.so.6.0"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOImage-pv6.0.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOImage-pv6.0.so.6.0"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOImage-pv6.0.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOImage-pv6.0.so.6.0"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOImage-pv6.0.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:"
74  NEW_RPATH "\$ORIGIN")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/bin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOImage-pv6.0.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkBMPReader.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkBMPWriter.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkDEMReader.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkDICOMImageReader.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkGESignaReader.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkHDRReader.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkImageExport.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkImageImport.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkImageImportExecutive.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkImageReader.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkImageReader2.h"
102  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkImageReader2Collection.h"
103  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkImageReader2Factory.h"
104  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkImageWriter.h"
105  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkJPEGReader.h"
106  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkJPEGWriter.h"
107  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkJSONImageWriter.h"
108  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkMedicalImageProperties.h"
109  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkMedicalImageReader2.h"
110  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkMetaImageReader.h"
111  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkMetaImageWriter.h"
112  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkMRCReader.h"
113  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkNIFTIImageHeader.h"
114  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkNIFTIImageReader.h"
115  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkNIFTIImageWriter.h"
116  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkNrrdReader.h"
117  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkOMETIFFReader.h"
118  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkPNGReader.h"
119  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkPNGWriter.h"
120  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkPNMReader.h"
121  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkPNMWriter.h"
122  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkPostScriptWriter.h"
123  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkSEPReader.h"
124  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkSLCReader.h"
125  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkTGAReader.h"
126  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkTIFFReader.h"
127  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkTIFFWriter.h"
128  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkVolume16Reader.h"
129  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Image/vtkVolumeReader.h"
130  )
131 endif()
132
133 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
134  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Image/vtkIOImageModule.h")
135 endif()
136
137 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
138  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Image/vtkIOImage.spdx")
139 endif()
140
